Petcock to Gas Tank seal
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Aug 5, 2009.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    I seem to be having problems getting a nice seal between the petcock and the Gas tank.....and seeing as how I need to remove the petcock again so I can get my tank repaired AGAIN I wanna do it right this time.
    First time I used the old O-Ring seal and some Petroleum resistant Gasket sealer.
    Honda cannot find a listing for a new O-Ring and I don't see one on Bike Bandit....
    Anyone have any ideas for me please?
  2. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    I replaced the o-ring on my petcock and haven't had any problems but I can't remember what diameter I used. I'm pretty sure it had a 2.5mm cross section though. Measure the diameter of the petcock tube and go from there. IIRC it should be around 8mm ID.
    FYI the BikeBandit part number is 7189447-001. It is part #5 on the Fuel Tank schematic. Costs $3.05 per part. IMO your better off trying to source a part locally as you'll end up paying a lot less. I got my o-ring out of an assortment set I have.
    -Jake
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Thanks...I don't think they thought that was the right seal
