Please help bike shuts off
Discussion in '1st & 2nd Generation 1983-1989' started by Crazy Russian, Apr 23, 2008.
  1. Crazy Russian
    Crazy Russian New Member
    Hello, I'm new to this forum but I just got some problems with my bike and don't know where to start.
    I have a 84 vf700 interceptor, today when i went out for a ride it lost power after 3 minutes of riding and the taillight light came one kind of blinking. After i put it in neutral the neutral light was blinking too. RPMs were about 1000 and would not go higher but the tachometer was showing 4-5k. I turned the bike off and it would not turn back on at all, light wouldn't come up either when i turn the key on. After about 3 minutes everything went to normal and bike run good
    for another 3-5 min then it started again. Can anybody please help me, bike run good last night when I took it for a two hour ride, didn't have any problems.:frown:
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    I'd check the plug going to the R/R. It will get hot and lose the connection. These are classic signs.
  3. drewl
    drewl Insider
    Virginia Beach, Va
    That would be a good place to start. R/R
  4. RVFR
    Yep RR. Reason you can restart is the battery will recharge it's self a bit, but it won't last long.
  5. Crazy Russian
    Do you mean spark plug to the rear right cilinder? The first thing I did is replaced them.
  6. soundmaster31
    soundmaster31 New Member
    Jackson, Michigan
    regulator/rectifier. on a 5th gen (1998) it looks like the dohicky with the chrome computer fan zip tied to it in my photo. looks like a heat sink about the size of a 3x5 card. Check the wires and plugs running to and from it. A multimeter helps out a lot if you need to test different parts on your electrical system. they run about 15 bucks.
      File size:
      55.4 KB
  7. masonv45
    masonv45 New Member
    On your bike, it should be under the left side plastic cover under your seat. The connector to the stator is not really designed to handle the current the stator is putting out if the connections are not 100% perfect. One of the common fixes is to remove the connector completely and solder the wires together.
    Before you break out the soldering iron, use your manual and check the RR and stator with a multimeter.
  8. Crazy Russian
    I don't have the manual for it, do you know what should I check for, I do have a multimiter.
  9. Pearl-93
    Pearl-93 New Member
    Elkridge, MD
    Lose or fried connections.
    I recently replaced the staor and R/R...new connections, plugs, wiring, eqpm.
    etc, etc, etc...
    After about a week i experienced similar problems.
    Come to find out after a thorough check, to the positive connection from R/R was loose and the contact point was the weak link.
    It wasnt feeding the starter solenoid and battery as it should because of loose connection.
    Battery Voltage was good, the bike would run weak and just cut out after getting warm and going over a bump or two in the road.
    Cutting out with normal operating voltage (14.8v) is probably a sign of a bad connection somewhere along the charging section of the wiring harness.
    in my experience anyway...
    -S
  10. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Trun your multimeter to the 20 volt setting. Now with the bike running, in neutral, rev the engine to 4-5000 rpms and hold it there and see what your meter displays. You may need another person to hold the meter tot the battery while you do this.
    It should be around 14.4 volts or so.
    BZ
  11. soundmaster31
    Jackson, Michigan
    buy a pair of alligator clips for your voltmeter....works wonders when you can work hands free
  12. Crazy Russian
    You guys are awesome this is one of the nicest forums i been to in a while.
    I'll check that as soon as I get to my bike and will let you know. I just broke my brake lines in my car yesterday, so now i have no transportation:frown:
  13. Crazy Russian
    so I have checked the voltage on the battery and it was 14V did it for like min at 4000 rpms but then after i shut it off it went dead again for like 3 min. The R/R has two connectors, one with three wires (coming out of alternator, or what ever you call it on the bike) and another one with five, can I check that some how?
  14. KingFatty
    KingFatty New Member
  15. Crazy Russian
    I do have a multimiter and i know how to use it, it just I don't have the manual and I don't know where and at what time there should be voltage. any ideas?
  16. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    Yes Buy a manual, it will be worth the money and will add years to your life. and your bikes life as well. just my 2 cents
  17. Crazy Russian
    so where is the best place to buy manual?
  18. soundmaster31
    Jackson, Michigan
  19. Crazy Russian
    Thank you very very much to every one. I have rewire the three wire conector that goes to R/R and now bike works good, just went out last night, had to turn around though, girl was freezing in the back lol.
    Thank you to every one again you guys are alot of help!!!!!!!:smile:
  20. Packman
    Packman New Member
    Arlington, WA
