Please help. fi light come on bike won't start.
Discussion in '6th Generation 2002-2013' started by openroad83, Aug 3, 2014.
  1. openroad83
    openroad83 New Member
    Llandybie, United Kingdom
    Hi I've just bought a 2003 vfr800 vtec today rode 100 miles then had the 1st engine cut out while on the move engine restarted then 70 miles later it did it again and then another 2 time over the nexts 30 miles. I pulled in the services to fill up it started fine then I rode it 20 meters to park up and pay. Came back out bike fires up then die straight away the fi light comes on while trying to start then goes off.
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    Might be faulty engine Stop Switch, turn it off and on a few times.
  3. TOE CUTTER
    Had similar problem last year, went over the bike from head to toe, ended up being stop switch as Allyance suggested.
  4. openroad83
    Recovery lorry bloke thinks it's a bad earth. I'm booking it in to a garage. I'm not messing with this bike. Cost me too much.
  5. Allyance
    Allyance Member
    Germany
    The +12vdc feed to the Stop/Start Switch feeds the ignition switch (when ON), switch contacts get dirty, not hard to clean. Requires separating right switch assembly and cleaning.
  6. openroad83
    got home from work today and tried to start the bike. started straight away not a problem then i was checking the light an put the high beam on and it cut the engine and would not start all i was getting was electrical buzzing sound that stop starts when i put the indicators on. the horn works fine. i have got this on video and i will post a youtube link of it once uploaded for you to watch and comment.
  7. Allyance
    Allyance Member
    Germany
    Now that sounds more like a bad ground, devices feeding back through other devices to find ground. Check all you connectors and ground connections.
  8. Scubalong
    Check battery connectors please
  9. NormK
    NormK New Member
    And check the battery earth to frame, take it off clean and refit, one that is easily overlooked
  10. openroad83
    [video=youtube_share;u8akOqVdb1E]http://youtu.be/u8akOqVdb1E[/video] this is a video of whats happening to my bike at the mo. i've not had chance to check anything apart from wiggle wires to see if its a dodgy connector. i have noticed that when the bike won'y start all for indicators and the side light are on at the same time but no main beam and i get the electrical buzzing sound
  11. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Here in the US, there was a recall notice issued by Honda on the 2002 to 2005 models. It involved a wiring harness up front. I don't know if this was a worldwide recall? But if so, a call to Honda or the dealer, run your VIN, and that will tell you if the recall was done.
    I don't know if you're problem is related to it, but can't hurt to check.
  12. openroad83
    ive found an adobe page that says which bikes are affected and between which vin numbers and mine is in the middle of one but it says it american honda not uk honda. i'll try and find a number and give them a bell
  13. openroad83
    IT'S FIXED AND I DIDN'T HAVE TO TAKE IT TO THE GARAGE. I DID IT MYSELF. it was a loose connection with this yellow block under the left front pannel. i don't know what it is 10550917_10204196134721519_335582279906348105_n.jpg
  14. Allyance
    Allyance Member
    Germany
    I have a 2003 and have had front fairing off many times (LED Headlight installs), I don't remember seeing anything yellow! Might be previous owner put something in.
  15. openroad83
    it was wrapped in black insulation tape but i pulled it off to move connector and then replaced it.
