Plug wire Q
Discussion in 'Mechanics Garage' started by sublunacy, Apr 2, 2011.
  1. sublunacy
    sublunacy New Member
    I upgraded my vf5oo with accel coils and supressor core wires. Both coils sit over top the rear cylinder now. anyway my question is- Is there a minimum length needed for the suppressor wires. Because the rear wires will be 4-5 inches/ but the front would be around 24 inches. Im worried the short wires will not have enough resistance. Maybe im not seeing it clearly? It wouldn't be a problem with the origanol non resistor wires but now??
    Thanks guys
    Not to worry !
    Unless your engine is modified, the stock coils and wires work fine.
    Original wires are solid core with resistor end caps.
    Just don't use a resistor plug cap together with resistance wire.
