Power commader problems
Discussion in 'Mechanics Garage' started by joyousjake, Sep 5, 2006.
  1. joyousjake
    joyousjake New Member
    Hello to all.
    I have recntly put a PCII into my UK '99 vfr800 and i am having nothing but problems with it.
    My setup is a '99 bike with K&N filters, iridium sparks and a micron can.
    I use standard 95 ron unleaded and so loaded the map (004 i believe) which is for the micron K&N setup with RON above 93.
    At low revs the bike judders and if you are at around 2-2.5k rpm and give it a handfull on the throttle the bike stutters so hard that it nearly stalls and i nearly fall off... Not good!
    Has anyone els had this problem and if so what solved it? I'm thinking of solving it by getting rid of the PC altogether! :frown:
  2. canib
    canib New Member
    Las Vegas
    Try starting with the base map. (0 map). The base map on my 06 cleared up 'snatchy' throttle and low rev sputtering. From there try a map for just the microns. Then move up to maps for more and more modded bikes.
  3. mello dude
    Romania
    I have a PCII on my '98. I have a BMC air filter and thermal wrapped stock headers with a Carbon Fibre slip-on. I am using the base map for the moment. The bike runs so much noticeably better than stock, so I havent been tempted yet to start playing with more appropriate maps, although I probably will eventually. Right now I am just having a blast just riding it. BTW - the low end runs really well, no stumbles or anything.
  4. joyousjake
    thanks for your advice. Looks like i should restore the PCII to stock settings. The map for the setup i have is so spluttery its dangerous. It cut out on me the other day at the low revs so much that it stalled as i was turning a corner and i dropped it. Could have been really nasty!
  5. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    When you have the base map installed it should run much better. If not then you may have a messed up PC and a switch back to stock will confirm this.
  6. reg71
    Sikeston, MO
    I also noticed when I first put my PCII on my 98 that it stumbled twice but at very low RPM. I think I was in 2nd going about 25-30 mph and it was a very slight hesitation. I wasn't starting to add throttle or anything. I bought it used, though so the map is whatever the last guy had. I'm waiting for a friend to loan my a connector to use a USB cable with the old 9 pin serial on the PC to get a custom map. I did notice that when under power the bike feels stronger now. It even started lifting the front tire once going into 3rd gear which I don't think it had ever done.
  7. joyousjake
    UNBELIEVABLE...
    I sent the same message as this post to the guys at dynojet and they replied..
    "Sorry for the problems, this can be a common fault with the PCII's on the VFR, if you would like to return the unit direct to myself, I will modify the unit and return it back to you ASAP. All free of charge of course"
    EXCELLENT:biggrin:
  8. RedVFR
    RedVFR New Member
    Spokane, WA
    Wow! Way to stand behind a product!
