Power problem...
Discussion in 'Mechanics Garage' started by h3rman, Aug 10, 2009.
  1. h3rman
    h3rman New Member
    Lucan
    Hello...
    I´m having some problem with electricity...
    Once i´ve turned the key there is no head lights, indicators glowing constantly, and i can hear noise from the clock section...if i remove 20a headlight fuse everything disappears and it is no lights of course...when indicator is turned on noise is pulsing with it...Where is the problem?
    Best regards
    YOU may have bad wiring harness to headlights??
    Also,check wires at starter relay for melting/burning.....
    check main 30amp fuse on starter relay.
