premium or regular?
Discussion in 'Mechanics Garage' started by daveyto, Apr 6, 2010.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    Can I use regular gas in my 91 vfr?
  2. k1c
    k1c New Member
    Northern New York
    You could probably burn diesel in one of these things, but not recommended.
    I use whatever midgrade. Regular works just fine, but I was unnerved by hearing the motor ping all the time, so I switched. Too many years riding old Brit Bikes, when pinging from the engine could often spell an impending disaster.
  3. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    You are wasting your money on premium gas unless you are experiencing pre-ignition engine knocking. Higher octange gas does not result in any power increase, it is designed to burn slower than lower octane.
    Rollin
  4. daveyto
    daveyto New Member
    Scarborough, Canada
    Thanks Rollin!
    Thats what I thought!!!
  5. daveyto
    daveyto New Member
    Scarborough, Canada
    thanks K1C!!!!
  6. crustyrider
    crustyrider New Member
    North Country, New York
    you could try Saki.....
    burn the regular gas........
  7. PONYBOY
    PONYBOY New Member
  8. daveyto
    daveyto New Member
    Scarborough, Canada
    regular gas is actually more volatile...i have heard...
  9. zielarz
    zielarz New Member
    detroit
    I know that honda.....is a japanese.....bike.....I'm sure many of u agree...eheh...but for those that didn't know....in usa... the lowest grade of gas......in avarage gas station is. 87.....premium....p...plua..... 89....93.....in europe...it starts with....95.....98.......103.....so...I would use higher grade of gas.....not becouse ....that's the grade of gas that they got in japan....but for better...clener....engine work.....not millage...
  10. jahlov420
    jahlov420 New Member
    Richmond, VA
    premium gas if available
  11. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    I believe that is a myth. At least in the US. The same degerents are in all of the grades. In Utah (or higher elevation/mtn states) regular is 85 octane. Unless your vehicle calls it out, I think it is more important where you guy your gas, than what octane it is.
  12. PONYBOY
    PONYBOY New Member
    If by "regular" gas you mean lower octane you are correct. The lower the octane rating the less resistance there is to burn, ie more volatile. The higher octane rating is purely and only made to prevent pre-ignition (knock) for higher cylinder pressure and higher compression engines.
    +1 VFR Lover, the source of your fuel and the time it has been sitting makes all the difference in the quality of the fuel and the power you can get from it. The detergent quality and ammount is supposed to be the same across all octanes. That being said there are fuel stations/companies that are classified as "Top Tier" fuel stations. This basically means that their fuel contains more, or more effective detergents, in the fuel to help keep a cleaner engine. You should be able to google Top Tier fuel stations and come up with a list of stations that qualify in your area.
  13. betarace
    betarace New Member
    Middleburg, VA
    89 is fine.
  14. daveyto
    daveyto New Member
    Scarborough, Canada
    TOP tier is what BMW told me to run in my car....
  15. PONYBOY
    PONYBOY New Member
    It's good stuff, I try to run nothin but Shell 93 in my cage and my VFR. Car is supercharged, I really don't have any choice.
  16. daveyto
    daveyto New Member
    Scarborough, Canada
    Whats a cage?
    Sorry but I am Canadian and its really not my fault...We don't get much up here...;-0)
  17. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Cage(r) = car.
  18. daveyto
    daveyto New Member
    Scarborough, Canada
    I only know a few cars that are supercharged...grand prix, mustangs, maybe a vetter or two...what car are you driving? the GTP is the only car i know of with a factory SC
  19. PyroMcnoob
    PyroMcnoob New Member
    Riverside, CA
    ok ok, so what grade should I be runnin' in my gen2? I live in So Cal, where we have 87, 89 and 91 octanes... I have always run 91, was told that's the way to go with older model bikes...
  20. 34468 Randy
    We have gone through this once before that I am aware of but none the less, occasional refreshers are good.
    When I bought mine "in the crate" in August 06, the mechanic at the shop I bought it from suggested I burn mid grade or 91 so I did for several months. The low an behold, I read the owner's manual. It said to burn regular or 89. So I switched. I observed absolutely no difference in performance or gas mileage burning the lower octain fuel. But the price difference is substantial. I don't know what the manual for a 91 says, but that is what you should burn. That manual obviously was put together in consultation with the engineers who developed your engine so it makes sence, they would know best what to burn.
    I have 91,000 km on mine, mostly burning the cheap stuff and it still runs like a cat.
