Good afternoon on this Easter Sunday. A beautiful day to check the VFR before I take it out next month in the Balkans and a piece of Greece. Let me first come to the subject of electronics. The regulator appears to be the only weak point, if I read here and there. People replace cabling and the voltage regulator for a better variant, it seems. The first tip I got is to take a look at the yellow connector behind the rear left fairing. So I just did. But something tells me the previous owner has already done something. The voltage regulator is of type SH603-12. See photos below. Has this been solved fine so well or do I need to do something to make it completely "bullet-proof"? Many thanks guys.
If that were my VFR I would be pulling that out of there and unwrapping the yellow tape to see what was done to the wiring. That seems to be a smaller regulator for a Honda Hornet, shadow that was shoehorned in there after the original died. I'd be putting in a quality MOSFET rectifier and direct connecting the yellow stator wires to it.
