Problem with 86 VFR750FG float bowl gaskets
Discussion in '1st & 2nd Generation 1983-1989' started by Dukiedook, Sep 29, 2010.
  1. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    I am needing to change at least one of my float bowl gaskets due to the drip drip on my alternator cover and ordered some replacement bowl gaskets from crc2online and ordered #BG-2675- the listing said it would fit 85-87 VF700/750 interceptors so I figured what the hell, 20 bucks is cheaper than about 40 for one and a bunch of stuff I don't need from Honda.
    Well, get it home and ordered a float needle I was hoping would work and they are too small, the package says K&L Supply #18-2675, same ones Squirrelman said to use for the application. Could these have been packaged wrong? I emailed crc2online about a possible mixup or maybe thery sent the wrong ones, I dunno.
    Anyone else have this problem?
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    That number on the crc2 online catalogue lists: VF700/750F Interceptor '84-'87
    Are the float bowls the same for the VF750 as well as the VFR750?
    Looks like the years may be incorrect on that website?
  3. MiddleTBabb
    MiddleTBabb New Member
    Murfreesboro, TN
    Wow sorry I have no answer but I am prolly gonna do this soon for my 86...please keep me posted!
  4. abner malidy
    abner malidy New Member
    mark it 8, dude
  5. abner malidy
    mark it 8, dude
    MTB- tyler, is that the honda "kool-aid" you're drinking there??? keep off the pipe brother!
  6. MiddleTBabb
    Murfreesboro, TN
    dude it tastes so good....BURP!
    :cool:
  7. Dukiedook
    Kansas City, USA
    **Best whiny voice**
    But I don't wanna put o-rings in!! I WANT squared gaskets!!!
    Yeah, probably was only for the 83-85 VF's, I was hoping the gamble would pay off.
  8. Dukiedook
    Kansas City, USA
    I don't know, I am wondering if they sent me the wrong gaskets.
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    Maybe Squirrelman can get you some info on where he gets the gaskets for the 2nd gens.
  10. squirrelman
    Yep, K&L Supply, #18-2675, good deal @ $38/set of 4. Any 'cycle dealer can order them.
    Package says it's for VF 750F, but i think i've used them on VFR '86/'87 also.
    I'm going to try the hydraulic shop make-a-gasket sometime soon.
  11. abner malidy
    mark it 8, dude
    SM- there ain't no "making" to it. the number that i listed in the thread i linked above is the exact fit for the 86-750 bowl gasket. the cross-section diameter is just big enough to provide a wee bit of "squish" upon closure, which the last OEM gasket i got really did not.
    unless the o-rings fail from swelling or becoming brittle over extended use/time,
    i can't see any reason to not see them as the cost and performance solution.
    the cost was 1 or 2 bucks each for local pickup about 5 miles from house.
    it is a common size that any decent HYD shop should have on hand.
  12. Bernieswanson
    Bernieswanson New Member
    Bellevue, WA
    Be very sure
    Be sure it is the bowl gaskets. I recall the same problems of gas dripping from the bowls but it was not the bowl gaskets. The gas was leaking on top of the carb from the fuel feed T-tubes that sends fuel to both sides of the carbs. The gas would run down from the top and drip off the bowls at the bottom. I wish I did not learn the hard way, but I got real good at removing and replacing the carbs till I got it right. The o-rings were a cheap fix but difficult to get at. I did learn a whole bunch about how carbs work in the process. I believe it is hard to trace the leak without removing the tank and carbs. But if you had, say a long q-tip and stuck it on the top of the carbs and smell gas on it, it is not your float bowl gaskets. If it is the float bowl gaskets, be carfeful with the screws, they deform with ease. DAMHIK. I found a set of float bowl gaskets, but the are getting difficult to find. Of course I ended up not needing them because it still leaked gas. I hear that you can use large O-rings and see no reason why this would not work. Just do not over-torque the screws and use the correct screwdriver size.
  13. FstaRocka
    FstaRocka New Member
    Cape town, Seattle
    for reference, i bought very thin fuel rubber for pennies, simply traced out the shape of the float bowl and cut it out to pretty much cover the width of the two metal halves- mine have been sealing perfectly for 4 yrs now, not a drop. I left the old seals in to create a little bit of a wedge - but im sure this is not needed.
    Cheap fix and it works great -
