Problems keeping my 95 VFR running without the choke
Discussion in 'Mechanics Garage' started by redrocketryder, Sep 30, 2008.
  1. redrocketryder
    redrocketryder New Member
    Could anyone tell me what might be the problem if my bike will only run with the choke full on unless I rev it hard it won't die then.
  2. 15dollar
    15dollar New Member
    Conroe, Texas
    Plugged fuel filter or dirty pilot jets would be my first guesses.
  3. squirrelman
    time to try SeaFoam to clear carb jets.
  4. Viffer66
    Viffer66 New Member
    Washington, DC
    Don't know if you've resolved this yet but have you adjusted the idle screw at all? It's just inside the fairing by left knee. Mine was idling poorly this Spring...lil twist....idles like a champ!
    Good luck!
  5. powderrecon
    powderrecon New Member
    Seattle
    Low speed idle jets clogged?
  6. RVFR
    Vacuum leak. Mine did this a couple years ago, then decided it was close enough for the 32K service too, So killed two birds in one throw, on the matter of it not running well with out choke seems on mine the little rubber plug that covers the the port for the sync of the carbs was missing, so once a plug was back on wa'La everything was fine.
  7. b1pig
    b1pig New Member
    Ray City, GA
    since this is the same basic topic i dont guess it qualifies as a hijack... :)
    got a '84 750 that i just got this weekend. at first, it would not idle at all unless the choke was on full. I've tinkered with it here and there. I removed the tank and rinsed it out.... the gas that was in it was at least 2 years old. i imagine that the carbs need to removed, cleaned and synch'd.... but with barely 1/4 of a tank of premium run through it, it is now idling with about 1/2 choke and will run with the choke off so long as i keep the throttle on. once it drops below 2000 rpm with the choke off, the engine stalls out.
    it will run fine with the choke on half, fires up every time. when pulling off there is a very noticable surge. when dragging the clutch the engine surges say, between 2500-3500 rpm until the clutch is fully engaged. the power is also way off. once over 4000 rpm, it runs good. the first night it wouldnt run past 8500 rpm, but now will pull decently up to 10,000-ish.
    Of note is when it's idling with the choke and when i'm holding the throttle open with the choke off, there is an audible sucking. not usre if it is a vaccum leak or just the air pulling through the carbs. where can i find the synchronizing ports, and can they be located without removing the tank and airbox?
    besides seafoam (which is what i plan to run once i run the tank down and get the new petcock in) any other ideas.
    thanks. :)
  8. masonv45
    masonv45 New Member
    Read and learn: wiki.sabmagfaq.org
  9. b1pig
    b1pig New Member
    Ray City, GA
    oh, man. excellent link. thanks a bunch.:thumb:
