I'm trying to add heated grips to my 2010 VFR 1200 is there a technical reason you can't use a newer (more available) OEM Honda heated grip? The Africa twin 2016 OEM heated grips are available and look to have the same hookup for throttle cable and dimensions unless I'm mistaken, the part I'm uncertain of is it possible? I'm sure the plug itself is unlikely to simply work but that's an easy enough fix, any help would be appreciated
