Question about vf500f brakes
Discussion in '1st & 2nd Generation 1983-1989' started by Octanis, Dec 10, 2008.
  1. Octanis
    Octanis New Member
    How thick are new front brake rotors?
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    I cannot answer your question directly, but MOST motorcycle and automotive brake rotors have a "wear limit" stamped into the rotor carrier.
    Original thickness is not what you need to know, only that the rotor cannot be thinner than the size stamped on it...
    ...unless you're tyring to fit non-VF500 rotors on your bike...
  3. Octanis
    Octanis New Member
    I'm trying to fit non-vf rotors or trying to find someone to make new ones.
  4. VT Viffer
    South Carolina
    One way to check that's not reall scientific is to push the caliper pistons back into the caliper, install new pads in one caliper, and measure the space between them, adding a millimeter for spacing.
    Having custom rotors made is a VERY expensive proposition.
    I'll let the VF500 guys chime in here - you might be able to get some CBR rotors to fit or something...:unsure:
  5. Octanis
    Octanis New Member
    I know that blackbird rear rotor is very close but...
  6. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Answer - 5mm
  7. squirrelman
    if you want to check total wear....
    there is usually an UNworn area at extreme outer edge of the rotor for comparison.....
