Question/poll: VFR750 temp gauge reading cold in winter- what's yours say?
Discussion in '3rd & 4th Generation 1990-1997' started by J-Rod, Nov 9, 2013.
  1. J-Rod
    J-Rod New Member
    Irish Hills
    Hey all. '95 VFR750 owner here with a temp gauge question, or poll if you will. I'm heading into my first winter riding season with her and now that the temps are in the 30's my bike doesn't seem to get up to "normal" temps, well according to the gauge anyway. I commute 30 miles mostly freeway and the gauge barely hits the C mark at best. Summer months it read in the normal range. I understand its sort of an arbitrary gauge reading since there's no actual number reading but I still want to be sure its getting hot enough while riding in winter. Last night after my commute home I used my infrared thermometer and shot into the oil fill plug hole- the temp reading on the clutch hub was about 155* Which seems low to me... I also understand it could be a sticky thermostat, but want some feedback before I roll her onto the lift and get into all that.
    Wondering what the rest of you are experiencing in similar weather conditions?
    Thanks in advance. -JD
    It's not at all unusual to need to block the radiator a bit and tape over the oil cooler to get anywhere near optimum operating temp in cold weather.
    Try sliding a cardboard cover that blocks about 1/4 of the radiator under the screen.
  3. tinkerinWstuff
    I disagree. I've ridden at freezing temps in the snow and still hold 168 degrees. My third gen also held temp well in cold weather. In the years I've hung around vfrworld, it seems more common for tstats to fail in the open position and not closed.
    Your problem is, you have to remove the carb assembly to change the 'stat. It will make you angry.
    Don't remove the carbs from the plenum plate and be sure to remove as a complete assembly.
  4. thegreatnobody
    thegreatnobody New Member
    Little Rock
    When I first got the bike, mine ran cold. Replaced with Gen Honda T-stat--still ran cold.
    That's kinda how they roll.
    I blame the NACA ducts.
  5. Bryan88
    South Africa
    Durban, South Africa
    Mine runs cold, only heats up if I get stuck in traffic.
  6. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    Mine runs cold as well. I was also thinking of changing the t-stat. Seeing how it doesn't change anything, I guess I won't.
    It looks like Squirrelman has the right answer, after all. Unless you want to go :crazy: and build a controllable shutter system.
  7. kennybobby
    kennybobby New Member
    IIRC these are double-action thermostats with two plunger rods, so twice as much chance to fail as a single rod unit, and twice as expensive to replace, plus a hassle to access and remove. Definitely a FUBAR design.
    So in my troubleshooting and testing i've used strips of duct tape across the radiator to regulate temperature and increase fuel economy in the process--had to cover nearly 3/4 just to get it up to normal operating temps in all but the hottest part of summer. Squirrel's idea of cardboard sheet may be easier to test and adjust quickly--wish i had thought of that before i stickified everything with that dam tape...
  8. tinkerinWstuff
    I guess I have to get the gopro out to prove a good t'stat does make a difference.
    Also, on my Civic headgasket project I just finished; the brand new t'stat worked correctly for the first test drive and then opened too early for each drive afterword. I immediately replaced it with another new one and it works properly. If that happened on my VFR, I'd probably go postal.
  9. J-Rod
    J-Rod New Member
    Irish Hills
    Thanks for the insights everyone. Sounds like the way to go is a simple shield on the radiator vs. tearing into the bike to get to the t stat! Plus I don't relish the idea of doing all that work just to have it not make much of a difference. Maybe if I got the bike apart for something else I'll go ahead and swap it.
    Do I even want to know what t stats for these things cost?
  10. tinkerinWstuff
    I don't remember them costing much. A little poking around and some say it's the same as some of the Civics if I remember right.
  11. J-Rod
    J-Rod New Member
    Irish Hills
    Ah ok. I'll check with bike bandit and maybe grab one to have on hand. Are there any aftermarket upgraded ones? If I do it I only wanna do it once!
  12. ridervfr
    I had a lousy Kawasaki that I taped up the cardboard to for the winter and it still ran like shite. The trucks up North would do that too!
    My VFR was a winter inhabitant for 5 years up North and when I would go oot in the winter, the fan would never come on, no matter how hard, fast, slow you rode it.
    That is ions ago, I have gotten softer and would not tolerate that miserable weather on two wheels. Cardboard is cheap, nothing to lose, happy riding...
  13. tinkerinWstuff
    Cardboard also turns to mush when it gets wet and comes apart. The fan comes on at 220. T'stat is supposed to open at 170. My fan doesn't come on in the cold either but she still holds 168 degrees and that's with an oversized oil cooler.
    Diesel trucks in the cold are another story. They do not generate any heat if they are not working hard. My cummins can idle for 5-10 minutes and you can lay a bare hand on the exhaust manifold. Try that on a gasoline engine. If I'm idling while coasting down the mountain then I'll lose all the heat in the engine.
  14. VT Viffer
    VT Viffer New Member
    South Carolina
    My 4G has ALWAYS seemed to run 'cold' and registers only slightly above 'C', except in traffic when it's above 75 degrees or so. When this happens, the fan kicks on when the gauge gets to about 2/3-3/4. After some airflow to the radiator, it resumes it's 'slightly above C' setting.
  15. squirrelman
    Not so much if it's inside a plastic bag.
    The bike normally runs cold in cold temps unless the rad is partially shielded. Try 3" strips at each side of radiator, but leave open at least 5" in the middle so the fan can work if needed.
    Vary the area of the radiator block you need to run proper temp, say 185-190F. in whatever ambient you have. Northern motorists know this instinctively, and in Canada, it's taught in pre-K.
  16. tinkerinWstuff
    Crusty would fix his bike with cardboard and plastic bags
  17. J-Rod
    J-Rod New Member
    Irish Hills
    Ended up putting a cover on the oil cooler and using a piece of aluminum flashing to cover a 1/3 of the radiator. She now registers in the low side of the normal range when riding casually and mid normal when pushing her a bit.
    FYI I bought the 5"x7" flashing from Home Depot in the roofing section for $2.77 and you get ten pieces in the package. Had to trim a bit to fit but works great and no worries when it gets wet.
  18. tinkerinWstuff
    After all that effort, you would have been half way to fixing it correctly.
  19. J-Rod
    J-Rod New Member
    Irish Hills
    So pulling the side fairing, carbs, draining coolant and pulling apart thermostat housing is as easy as slipping a piece of sheet aluminum over the radiator? Moreover, based on what other riders have said, replacing thermo might possibly not have any affect anyway?..
    Sorry, don't see your logic, but thanks for chiming in!
  20. tinkerinWstuff
    Don't forget the trip to the store, shaping of the material, having to remove it again in warmer weather.
    And you cherry picked the answers you wanted to hear and took the lazy way as opposed to what most mechanics would consider the "right" way. But it's your bike and if you're happy, so be it.
    Ride on and ride safe out there.
