R/R grounding question
Discussion in 'Mechanics Garage' started by Junyr, Mar 8, 2011.
  1. Junyr
    Junyr New Member
    Des Moines, Iowa, United States
    I was reading somewhere else about a procedure to tap into the green ground wire coming out of the R/R and ground it to a place on the frame close to the R/R. Reason is giving the R/R a faster/better/more efficient grounding point.
    The picture that was posted had what looked to be about a 6 inch wire spliced in using one of those "clamp" type wire taps that bascially makes a "T". The pigtail coming off of the existing RR ground wire is then connected to one of the bolts that mounts the RR to the frame.
    Would this be worth doing do you suppose?
  2. rangemaster
    rangemaster New Member
    Albuquerque, New Mexico
    R/R grounding
    On my '97 I ran a 10 gauge wire strait to the frame ground point on the right side. This, among other things I did, have resulted in trouble free riding for over 2 years now.
  3. squirrelman
    Hell, yes !
    That is good. Look at the r/r from an '87 CBR600, which has that extra wire grounded to frame nearby. Problem with the VFR is that it runs too many components to ground through one small wire.
  4. Junyr
    Junyr New Member
    Any idea what gauge wire that is coming out of the r/r? I'll do this, it can't hurt, just want to get the right size wiretap.
  5. squirrelman
    YOU can't go wrong going too big.
  6. Junyr
    Junyr New Member
    Arent those T type wire taps sized for the wire you're tapping into? I wouldn't want to get one for a 10g wire and have the wire coming out of the R/R being a 16g wire...
  7. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    As far as R/R and main harness goes, all I can say is VFRness - wiremybike.com
