r/r not so hot
Discussion in 'Mechanics Garage' started by slickster, Jun 7, 2015.
  1. slickster
    slickster New Member
    Hi guys slickster again
    Took my 2005 vfr for a good ride saturday two days ago after I had my main and sub main harness installed by local dealer. Good report no problems, and touched r/r as I was riding and it was warm but
    not hot enough to burn me. I did not check the r/r as I was moving the last time before I had harnesses replaced, so should I still replace r/r or just carry a back up of series type/
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    Are you saying the bike is charging fine, but the R/R is kinda warm to the touch? <--- that's the only issue?
  3. slickster
    Yes it is not as hot as before, the new harness but I did not check the r/r heat when the bike was in motion before. But am going to carry anew r/r, because the is still 10 years old. thanks for reading
    slickster signing off
  4. Allyance
    Allyance Member
    Germany
    East Bay, California
    R/Rs shunt un-used power to ground, that is why they run hot, which is normal.
