R/R recall? "New" OEM R/R?
Discussion in '6th Generation 2002-2013' started by Echo3Niner, Sep 28, 2009.
  1. Echo3Niner
    Echo3Niner New Member
    Chicagoland, NW - IN
    I kinda hijacked another thread with this question, so thought I'd just start a new one to give him back his thread.
    I have read on so many threads, so much info about the R/R issue on Viffers that I am totally confused now.
    On many threads (here and VFRD) I have seen comparison pictures of R/R's; on older OEM (with small fins), a newer OEM (with larger fins), and aftermarket (also with larger fins). On those threads people mention the newer OEM R/R was for a "recall", and at some point became production on the bikes; however, I can't seem to nail down which year this newer OEM part became production.
    In addition, people all seem to agree that there are other issues that impact the R/R, including the wires being too small of gauge. So, that replacing just the R/R won't guarantee you've addressed the issue. Many have recommended an aftermarket wire harness and R/R; however just as many say they aren't all they cracked up to be. Others have also recommended putting a computer CPU fan on the R/R.
    So, I went out and decided to look for the recall notice, thinking that might clear it up for me... I cannot find a recall notice for the R/R. The only electrical recall notice I found was below:
    Recall ID #27884 - ELECTRICAL SYSTEM:WIRING
    Recall Date AUG 15, 2007
    Component ELECTRICAL SYSTEM:WIRING
    Potential Motorcycles Affected 6952 Recall Details
    Motorcycle Affected 2005-2002 HONDA VFR800
    Summary
    ON CERTAIN MOTORCYCLES, THE FRONT FAIRING SUB-HARNESS (SECTION OF THE WIRING HARNESS) TRANSFERS THE ELECTRICAL GROUNDING LOAD OF THE HEADLIGHTS, FRONT TURN SIGNALS, INSTRUMENT PANEL, AND VARIOUS RELAYS TO THE MAIN WIRING HARNESS VIA AN 18-PIN CONNECTOR. UNDER CERTAIN CONDITIONS, THE GROUND WIRE TERMINALS INSIDE THE CONNECTOR CAN OVERHEAT, RESULTING IN MELTING OF THE CONNECTOR AND A LOSS OF POWER TO VARIOUS CIRCUITS.
    Consequence
    AS A RESULT, A LOSS OF CRITICAL LIGHTING OR ENGINE POWER COULD OCCUR WITHOUT WARNING, WHICH COULD CAUSE A CRASH.
    Remedy
    DEALERS WILL INSTALL A RE-DESIGNED SUB-HARNESS. IF DAMAGE IS FOUND, THE MAIN WIRING HARNESS WILL ALSO BE REPLACED FREE OF CHARGE. AN INTERIM LETTER WAS MAILED TO OWNERS ON SEPTEMBER 26, 2007. OWNERS WERE RE-NOTIFIED ON NOVEMBER 10, 2007, TO TAKE THEIR MOTORCYCLES TO DEALERS TO HAVE THE PARTS INSTALLED. OWNERS MAY CONTACT HONDA AT 1-866-784-1870.
    6952
    Notes
    HONDA (AMERICAN HONDA MOTOR CO.)
    DOES ANYONE have DEFINITIVE info on this issue?
    From the 2006 model year, the above issue is fixed, yes?
    If there is a "newer" OEM R/R, with bigger fins, what model year did that go into the production bikes?
    Does just having the "newer" OEM R/R 'fix' the problem?
    Is there a model year that from that point going forward HAS NOT had R/R issues?
  2. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    I though 07+ newer ones had the newest ones already. I have a 02 but i haven't had any problems yet...YET.
