Radiator cleanout and fins cleaning methods
Discussion in 'Mechanics Garage' started by mello dude, Apr 17, 2025.
  1. mello dude
    Romania
    I'm deep into a coolant system R&R, for new hoses, thermostat,radiators cleaned etc.
    Its turning into competing with my least favorite job, bleeding a bone dry new brake setup.
    Hoses have welded themselves to the fittings, have to pick at each one, sometimes goto the razor blade.
    Waht a labyrinth of hoses, bleah. (ok, I have no patience)
    Hey Resto guys... Capt, Bazza, Stray, linkken, sixdog, bmart.. sry if I missed anyone.
    Anyhoo, whats you guys method to clean the radiators?
    run the engine up to temp with a big box of baking soda mixed into the water (not antifreeze) then drain it to degease and clean. and there usta be rad specialists in town that did great work, 99% gone now.
  3. NorcalBoy
    Any radiator shop should have a hot tank that should do the trick.
  4. mello dude
    Romania
    Too late.. parts are everywhere...
    If I could find one... Radiators are all aluminum... X2
  5. NorcalBoy
    Most radiators are aluminum, and even some are partially plastic today. There has to be a radiator repair shop in your vicinity. I would be hesitant to stick anything into my cooling system that I couldn't 100% ensure that I could get it out.
    BMWguy22 likes this.
  6. bmart
    bmart Insider
    Charlotte, NC
    In fairness, I flush the track bike radiators every other year and don't think I've ever done a street bike that wasn't having troubles. When maintained, I've never had this need. When I was very young, I remember my dad sending radiators to shops that dipped them. Those places may still be around and offer a solution or advice. Good luck!
    If needed, I am fortunate enough to have a true, old school radiator shop about 20 minutes away. Not many of them left around. When I'm restoring a cooling system, I will flush into a container so I can see what is coming out. If super nasty, it goes to a pro. Think I've had to once. If not, I will flush with my garden hose for a little force (both into the rad and from the back, forward thru the fins), and follow up with a distilled water rinse to wait for restoration / assembly.
    And then I spend a romantic evening in my shop with a tiny flat blade screwdriver, a cold IPA, 2 fingers of whisky and some music straightening every goddamn fin.
    Same dude completely replaced / restored the cooling system and heater core on my '71 GMC. Factory A/C... the heater core SUCKS BALLS to replace on that model. Like partially removing a fender SUCKS BALLS. Fuck it... I'll write the check on that one. I got bikes to work on.
    ridervfr likes this.
  8. mello dude
    Romania
    No shops here in my area of sleepy hollow... maybe I could look over in Columbus....
    Capt, you are way far more patient than I am... Seems the older I get, the less patient I get....
    Effe no for me on the fin job, fuck yes for an IPA and the whisky and music.
    Thanks all for the replys... :thumbs:
    :bruce2:
    Captain 80s likes this.
