Radiator is leaking
Discussion in 'Mechanics Garage' started by KarlR, Jul 4, 2024.
  1. KarlR
    KarlR New Member
    Esopus, NY
    Hi All, my 86 VF500 was warming up and I noticed a wet spot under it, coolant. On further investigation I could see a small stream shooting out near the bottom of the radiator.
    I am asking the helpful people here for guidance/options for replacement or recore.
  2. mello dude
    KarlR likes this.
  3. KarlR
    KarlR New Member
    Esopus, NY
    Thanks Mello Dude.
  4. squirrelman
    a big glob of jbweld is likely to fixit.
  5. Terry Smith
    I had a local auto repair place fix the radiator on my RF900; looked ugly but kept the green stuff inside.
  6. KarlR
    KarlR New Member
    Esopus, NY
    Thanks Terry.
  7. KarlR
    KarlR New Member
    Esopus, NY
    Thanks Squirrelman. Do you know if this radiator is aluminum?
  8. KarlR
    KarlR New Member
    Esopus, NY
    FYI
    Myler’s says it is copper and they only do aluminum.
  9. squirrelman
    mostly is.
    sand and clean a dime-sized area around the leak and apply JB, wait 24 hrs. ive had a similar patch on an '86 vfr rad for about 25 years w no probs.........yet.
  10. KarlR
    KarlR New Member
    Esopus, NY
    OK, I will try that. Thank you.
  11. KarlR
    KarlR New Member
    Esopus, NY
    Got it off and stripped down. Did a pressure test. It is leaking from between fins in at least two places. Do you think the JB Weld is still a good solution? I can’t even see the exact spot of the holes.
  12. bmart
    bmart Member
    Charlotte, NC
    If you have one leak from age/corrosion, you'like have or will soon have more.
  13. KarlR
    KarlR New Member
    Esopus, NY
    so what are my options now? Another used one from the web.
  14. squirrelman
    replacement rad needed, but it doesnt cost much to try JB if you find the hole.
  15. KarlR
    KarlR New Member
    Esopus, NY
    My thoughts exactly. Any suggestions on a new one that isn’t $600 and a close match?
  16. squirrelman
    no clue. may be a chinese copy available, quality unknown.
  17. KarlR
    KarlR New Member
    Esopus, NY
    JB weld fixed one leak and two others showed up. I will try again, but I ordered a new aluminum radiator from the Netherlands. It was expensive $680, but my wife likes her mini ceptor.
    I am also replacing the thermostat since the coolant is drained, and a new fan switch.
  18. bmart
    bmart Member
    Charlotte, NC
    You're going to play whack a mole that way. And you'll eventually, sooner than later, be on a ride far from home when it blows...
  19. KarlR
    KarlR New Member
    Esopus, NY
    Yep, I agree. New aluminum radiator on order from CMSNL. I hope it fits right in.
    bmart likes this.
  20. KarlR
    KarlR New Member
    Esopus, NY
    Well the new rad came yesterday and I installed it without any issues. It is an exact replica of the Honda part. Highly recommend.
