Radiator Overflow
Discussion in '1st & 2nd Generation 1983-1989' started by a1gatorz, Oct 11, 2015.
  1. a1gatorz
    a1gatorz New Member
    Petaluma CA
    Hi all , I own a 1987 VFR700F2 & recently had my carbs rebuilt & I have just finished installing them . Everything is running great . Only problem now is I failed to take notice of witch Radiator hose went to witch outlet on the overflow tank. I know one goes from radiator to overflow tank & one comes out of overflow tank to drain under bike . I just don't know witch one went where ? On the overflow tank one nipple has a hose attached going to the bottom of the tank & the other nipple is molded into the top of the tank . Hoping some one hear with the same model can tell me the correct way to attach them ? Thank you for any help !
  2. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Hose that goes to "nipple" goes to the radiator. As the engine cools, coolant is siphoned back into radiator.
  3. a1gatorz
    a1gatorz New Member
    Petaluma CA
    Thanks Allyance , but witch nipple ? The nipple attached to the small hose that goes to bottom of the overflow tank or the other nipple that's molded into the top of the overflow tank ? Their are two nipples on top of my overflow bottle .
    The cap with the tube goes to rad (so it is submerged and can suck back).
    One molded into tank goes out bottom of bike (overflow)
  5. Allyance
    Allyance Insider
    Germany
    Was that a halloween pun? Probably spell check! Sorry didn't read it closely, Thanks Captain.
