Rear bolt/nut size?? Easy question.
Discussion in 'Mechanics Garage' started by Erk2006, Feb 16, 2009.
  1. Erk2006
    Erk2006 New Member
    I have a 1985 VFR500 that is missing the rear swing arm nut(the long one that holds the wheel to the swingarm), What size is this on my bike? I can't find the original and I don't want to take my wheel completely off.Any advice would be appreciated. Thanks
    -Eric
  2. Erk2006
    Erk2006 New Member
    Anyone? I need to know this ASAP as it's my only means of transportation as of right now. Thanks again.
    -Eric
  3. RWB25
    RWB25 New Member
    North Bay, Ontario
    Eric,
    Alll I have is the Honda Part #'s for the 83/84 VF750F, they should be similar.
    90121-MB2-000 Bolt, R, Swingarm Pivot
    90122-MB2-000 Bolt, L, Swingarm Pivot
    The manual has no specificiations for the part, just the part #'s.
    I hope that helps, in some way. If not, hopefully, someone else will chime in for you.
    EDIT: Crap. Sorry, mate. Those are the bolts for the actual swingarm to the frame and NOT the wheel.
    If you are talking about the long bolt that goes through the rear sprocket, flange and wheel.....
    42301-MB2-000 AXLE, RR Wheel
    And again, no specs on it, just the part #.
    Hope that helps....in some odd, twisted way.
