Rear Brake issue
Discussion in '8th Generation 2014-Present' started by Fly0ntheWall, Oct 20, 2018.
Tags:
  1. Fly0ntheWall
    Fly0ntheWall New Member
    I have a question for all who have an 8th gen to see if its just an isolated issue or if it's a common problem.
    I just recently bought a 2014 VFR literally with 0 miles on it from my dealer about 2 weeks ago and less than 150 miles in my rear brake started locking up. I wore the brakes in on the first 30 miles with different brake pressure with no issues. However once I started riding around mile 80 it started to feel sluggish and within minutes my rear brake was locked up with so much pressure my rotator was red hot. I am fairly certain that I was not dragging my brake. So I tested it yesterday and I didn't use my rear brake at all just to see if it would do it again and sure enough after about an hour of riding I had to pull over and let the brake cool so that I could free the wheel up and limp the bike back home.
    Has this happened to anyone else?
  2. Rsparky
    Rsparky New Member
    Not me. Assembly error at the dealer? Don't know how much they actually have to put together. There's no real "spring return" that I know of. Something is just binding when the hydraulics return.
  3. mello dude
    Typically it's an obstruction in the master cylinder that is blocking fluid return for the brakes. Bring it back to the dealer for repair under warranty.
    34468 Randy likes this.
  4. squirrelman
    be sure the mc is not over-filled, should have some air space above fluid level.
  5. Thumbs
    Thumbs Member
    Bath(ish)
    Read the PDI sheet they should have given you, it'll say if they changed the fluid before you purchased it
    If not the fluid is old and the system needs draining and new fluid ...Dot 4
  6. Fly0ntheWall
    Yeah I am figuring the dealer let something fall into my fluid when they filled it up
  7. Fly0ntheWall
    I have and they were replicate the issue so I'm waiting for them to give me a update on it on Monday
  8. 34468 Randy
    My Opinion. Don't touch anything on that bike other than user periodic checks and adjustments. The bike is new. The dealership needs to deal with it. If you monkey with anything, you can bet the dealership, when looking at it later, is going to say someone tampered with it and they are very likely to make you pay for something they did wrong, or was a factory defect. But I see you have the bike at the dealership now. Good for you.
    Bubba Utah likes this.
  9. fink
    fink Member
    Take it back to the dealers.
