rear brake peddle
Discussion in '6th Generation 2002-2013' started by openroad83, Aug 11, 2014.
  1. openroad83
    openroad83 New Member
    Llandybie, United Kingdom
    hi all . could some one post a picture of there rear brake peddle from the top looking down from the seat as i think my peddle is bent towards the engine and i want to compare, thanks
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    I would, but so is mine!
  3. nearfreezing
    nearfreezing New Member
    Worcester, MA
    Same here, wondering if replacing the pedal would reduce cramping since it's maxed out on adjustment.
  4. Allyance
    Allyance Member
    Germany
    Had to re-adjust mine when I put lowering blocks on.
  5. openroad83
    20140812_063517.jpg 20140812_063526.jpg this is my brake peddle does this look like its too close to the engine case. if so where can i get a replacement one in the uk
  6. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    From an 07:
    I'd say yours has been tweaked. Maybe from a tip-over (?).
  7. Scubalong
    Yup it should look like this....!
    If it is close to the cover then it has been lay down :sad:
  8. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Yep, yours is bent. Could have fallen over while stationary, check for grind marks on the edge of the pedal. If it fell over while stationary then there will just be a scuff or two, not grind marks like it slid along the ground. Also looks like the frame is shiny where the pedal has been rubbing on it.
    Maybe the PO had big feet and wanted it out of the way. Pretty unlikely but you never know.
  9. thegreatnobody
    thegreatnobody New Member
    Little Rock
    Take a tire iron, slide the socket end over the pedal, and slowly but firmly pull back straight. It won't break. Promise.
  10. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Better to remove it from the shaft first, just to be on the safe side. May not break but it could bend the shaft, not really likely but why take a chance.
  11. openroad83
    there is a scuff on bar end and engine casing. i work in metal workshop so will take it in and put a little heat into it just to be safe and not snap it. while we are talking about this area what are the bars at the end of the pegs called and where can i replacement
  12. Scubalong
    If you are talking about the feeler.....Most of us took them off :wink:
  13. openroad83
    yer think thats what they are my bike dont have them attached. i was always scrapping pegs on bandit but think the vfr are higher up and don't want to over push the bike. changing subject slightly. are vfr a bit tail happy as i'm sure ive had the back end spin up sideways while pushin through the corner.
