getting ready to bleed my brakes on '07 6th gen : a flare nut backed off on the rear union under the seat and i lost all the RMC fluid - according to guides, i see they use a bleeding nipple for the rear PCV on the right side (opp. the servo one by the battery) but mine has no bleed nipple. Just an allen set screw. Am i looking at the right valve? the only valve back there i see with a bleed nipple is the servo valve. thanks for any advice!
If your bike does NOT have ABS brakes, then you will have NO bleed valve on the right side rear PCV. That is on ABS bikes only. Here is link to great write-up on bleeding brakes complete with pics and everything. http://www.vfrdiscussion.com/index....es-wabs-on-6th-generation-the-ultimate-guide/
ok thanks! i had read and copied off that guide but i missed where it said non-ABS bikes dont have that bleeder. i appreciate the help!
