Rear Rotor Recommendations
Discussion in 'Mechanics Garage' started by Expvet, Jun 9, 2024.
  1. Expvet
    Expvet New Member
    Brooklyn, NY
    Looking to replace the rear rotor and pads on my 2006 non ABS VFR and am considering aftermarket. Any experience or recommendations on brands?
  2. bmart
    bmart Insider
    Charlotte, NC
    How many miles did you get out of it? Generally...they never wear, forget about wear out. Maybe a used one on fleabay?
  3. Expvet
    Expvet New Member
    Brooklyn, NY
    A little over 15000 miles. Is a bit warped due to caliper piston issue that has been corrected. Don’t want to go used to avoid the hassles if not as described. Looking at EBC or Galfer and hoping to get some feedback from anyone who has used them.
    bmart likes this.
  4. Expvet
    Expvet New Member
    Brooklyn, NY
    Confirmed via dial gauge that the 6th gen rear rotor is indeed warped. Now asking if anyone is familiar with a 6th gen rear rotor replacement. Seems like I will need to remove the axle to get the old rear rotor out. Is this correct?
