Rear Tail Light Flasher
Discussion in '6th Generation 2002-2013' started by Skyeric875, Mar 23, 2017.
  1. Skyeric875
    Skyeric875 New Member
    Hey guys. I got a 2002 VFR800 and I have seen a few bikes with tail light flashers. Those are the ones when you pull or step on a brake it will flash a few times then goes solid. Anyone have any? Please list what you bought or a link of it. I would appreciate how you wired it with some pictures. I'ts cheap insurance it lessens the risk of a rear end, and it looks pretty cool! Thanks.
  2. carlgustav
    carlgustav New Member
    Heart of Dixie
    wiremanjon likes this.
  3. Allyance
    Allyance Insider
    East Bay, California
    Check your state's regulations, they specify how many flashes, rate and duration.
  4. zombie
    zombie New Member
    Guelph Ontario
    I just had my '02 in for the wiring recall and they wouldn't hook up the flasher when they replaced all the wiring as they said it is illegal in Canada. People have told me that they noticed me in traffic specifically because of that, once I had a guy swerve around me when I stopped to turn that came up to me after to apologise and said that if my tail light had not been flashing he probably wouldn't have even noticed me at all.
    So I'm hooking it back up and if the police charge me then they charge me. Haven't had an issue in 4 years yet.
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I have one as well, and it DOES help.
    I don't recall the brand, but they all hook up the same.
  6. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    I've got the Kisan Tailblazer on 2 of my 3 motorcycles. The VFR is the only one without a Tailblazer because I just bought the bike. I did put a Kisan Pathblazer headlight modulator on the VFR and I guess I'll get around to the Tailblazer eventually.
  7. dvo
    dvo New Member
    Signal Dynamics BackOFF Wig Wag. Came with the 6th gen that I bought. I like it so much that I took it off and moved it to my 5th gen when I sold the 6th Gen. This is the perfect solution in my opinion.
  8. RllwJoe
    RllwJoe Member
  9. James Bond
    James Bond Member
    Dixie
    manindab0x81 likes this.
  10. Mark919
    Mark919 New Member
    Detroit Suburbs
    I also use the Signal Dynamics BackOFF but i chose to flash only an additional LED light bar that I have attached under the license plate. Anything that can grab the attention of a distracted driver behind me has to help!
  11. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    what colour is the live going to the brake light?
  12. Camp
    Camp New Member
    Easton, PA
    I use red/amber swithbacks in rear turns. Red center wire tapped to brake lights. Whole back end goes red with the brakes overidden to amber on the side a turn signal is turned on. Pretty cool & easy.
  13. raYzerman
    raYzerman Member
    Millgrove, ON
    On my FJR I had a light bar and the amber turns ran as running lights, flashed with the brakes too.... no LEO ever cared and I was all over the US and Canada with that bike. Rock on. Maybe California might be different about enforcement, but I wasn't there on that bike.
  14. 34468 Randy
    I don't think the back off flasher is illegal in BC at least. I've never came across it in our regs for the 25 years prior to my retirement in 2003. Wig Wag headlights or tail lights would be illegal though. You can have high/low modulating head lights on a motorcycle in BC. No other vehicles are allowed this feature. The BC Regulations say they are illegal but there is and exemption for motorcycles. One has to dig pretty deep in the Regs and a couple other Federal standards to find the exact authority. Most LEOs would stop at the onset and walk away from it. As someone has already stated, police are not likely to bother you about that. Who is to say a rider is not causing that flashing manually anyway. It is a possibility correct?
  15. Camp
    Camp New Member
    Easton, PA
    I ordered a backoff wig wag. Going to put it in the stashbox licence plate box and mount it with 2 magnifier type red led licence plate bolts from Superbright Leds. Should a nice contained unit, noticeable but not obnoxious. This way I can positap rather cut brake wires as well.
  16. 34468 Randy
    I have a modulating rear brake light. When I apply the brakes if goes Flash, flash, flash, on......flash flash flash on.... until you release the brakes. I am not sure of the legalities of this here because I had never come across it and never looked it up. It is an effective safety feature so I would never have bothered anyone with it before I was a biker anyway
