Rear Wheel Bearing
Discussion in '3rd & 4th Generation 1990-1997' started by LannyL81, Jun 25, 2022.
  1. LannyL81
    LannyL81 New Member
    Green Valley, Arizona
    Decided it was time to clean and re-grease the rear wheel bearing which required a purchase of a 46mm 1/2" drive socket for the axle nut. Had to use my electric torque wrench to get the axle nut off (yes, I un-staked it first).
    Had to tap the axle out with a rubber mallet.
    Small amount of corrosion on the axle, cleaned that off with emery cloth and steel wool.
    Wiped old grease out...which it seemed like there was not a lot of....brushed new grease in, rotated bearing, repeated several times.
    Thin grease film on axle and seals; axle slide easily back in, put the drive flange back on, washers in correct orientation, applied oil to axle threads and used my good 'ole Craftsman torque wrench set to 141 ft-lbs, with wife hold rear brake down, VFR on center stand, attempted to torque the axle nut....nope, rear brake would not hold.
    Put bike on side stand, with wife applying both front and rear brakes was able to torque to 141 ft lbs.
    Re-staked nut, taped cover in place....DONE!!
    Anyone want to purchase a 46mm 1/2" drive socket????.....
  3. LannyL81
    LannyL81 New Member
    Yep she was helpful.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Just nitpicking a bit, but if you lubricated the threads, you should reduce the torque setting by about 15%, so the setting should have been 125 ft. lbs.
  5. LannyL81
    LannyL81 New Member
    That is what I have been taught as well. However since the Service Manual stated to apply oil to the threads with the 141 ft lbs of torque that is what I did. I went back and forth on this, hopefully this is what those Honda engineers meant.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Good thinking, pretty unusual for torque settings to be for lubricated threads. But good catch.
  7. mello dude
    Romania
    A thing I came up with for the rear nut is a "monster torque" arm I made by drilling the hole pattern in an oak plank.... kick it on with the lug nuts....
    Works like a charm...
  8. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Sometimes ingenuity isn't pretty, but if it works, it's beautiful. :)
    Colddevil and mello dude like this.
