Rebuilt carb but no joy
Discussion in 'General VFR Discussions' started by eshibbs, Sep 21, 2020.
  1. eshibbs
    eshibbs New Member
    Hilton head Island sc
    had carbs rebuilt by Billies in Texas ,reinstalled will not start. Good spark, fuel in floats, good batt. will bark if i use start fluid in carb intakes but will not continue to run. Reinstall seemed strait forward so if anyone has a clue what I missed I sure could use the help.
    Scott
    i pm'ed you ;) tryin to help.
  3. Diving Pete
    i think your fuel pump may need to be primed.
  4. eshibbs
    eshibbs New Member
    Couldn’t open your message, sorry. 66 yr old Vfr rider with same bike since it was practically new. Never had a reason to think about switching till now.
  5. eshibbs
    eshibbs New Member
    Sounds reasonable. Any hints on the process
  6. squirrelman
    but, pete my good man, he sez float bowls are fulla gas !? he could maybe use the famous jumper wire on the pump relay to assure pump is powered up.
  7. eshibbs
    eshibbs New Member
    Where is the relay. I think I need to jump or replace. No current to fuel pump.
  8. squirrelman
    location info in service manual, downloadable here. u never stated what year the bike is..........
  9. eshibbs
    eshibbs New Member
    95-found relay, jumped the pins and fuel pump runs and fuel makes it as far as splitter to the fuel rails, sadly after that still won’t start unless I put fuel directly in the stacks
  10. squirrelman
    some obstruction ?? try blowing (low pressure) compressed air into the carb fuel line after draining whatever fuel is inside.
  11. Diving Pete
    Yep you are pulling the carbs off again
  12. squirrelman
    just needs access to fuel line into carbs, not to remove them, to try my suggestion above.
  13. Diving Pete
    I'll put a beer on the jets are clogged.
    Don't get me wrong I'd like this to be really easy to fix..
    But have been there on one on my bikes - rebuilt the carbs - full strip down, synched, bike ran awesomely for 30 minutes !!!!!
    Then had to do it again .. lol
  14. squirrelman
    i'd love to share that bass ale with you, but.......
    pete, my good man, he paid lotsa quid for a professional rebuild, so jets gotta be clean, doncha think ?
    i've offered to go through his carbs to find out what's wrong for a low, low price, but the responsibility is on the guy who got paid for the work, although i've heard he doesn't always answer his phone.
    i never think an idle jet is clean unless i can pass a .010" wire through it easily, guarantee my work and charge way less than his guy.
