Recommended Synthetic Oil for 5th gen?
Discussion in 'Mechanics Garage' started by EvilStig, Oct 27, 2012.
  1. EvilStig
    EvilStig New Member
    Hi, I'm trying to decide what's the best oil to buy for my 99 VFR. So far I'm looking at either Mobil 1 4T 10-40, Royal Purple Max-Cycle 10-40, or Red Line 10-40 motorcycle.
    I've had great experiences with Red Line and Royal Purple products in the past, but never tried using any of them on a wet clutch, so I don't know what to expect.
    What do people here use?
  2. mello dude
    You'll get 50 replys on this - I use this or that (I use the Mobil 4t) and everybody is crazy passionate that theirs is best. (Oil, tires, chains, chain lube, sprockets, batterys. Round and round.) - I'm tempted to go to the Rotella T6 - the Mobil is getting damned expensive. -- Suggest do a search.
    -I think the top 3 will be Mobil 4t, Amsoil, Rotella. (Not trying to say any one is better than the other, just trying to help.)
    The only way to know for a fact of how your oil is working is to get it tested at the end of the oil change. Blackstone Labs does that.
  3. silverbullet132
    silverbullet132 New Member
    Rotella T6 has worked well for me, shifts like a hot knife through butter now :)
  4. mello dude
    ^^^ Lost count on how many times I'm standing in the store looking at the roughly $18 gallon bottle of T6 and then the $8 -10 quart bottle of 4T. Just cant get over the hump yet, even though there's umpteen thousand threads on how great T6 is.
  5. bitterpil
    bitterpil New Member
    Northern Virginia
    +1 MD is right.. You will get a boat load of suggestions. The mobil 1 4t is easy for me to get at the local auto supply store. . Many carry motorcycle oil now. If not, most will bring it in for you if they know you are looking for it. Rotalla T is easy too. Get it at Walmart.
    I think he is right with the top three oils suggested as well. I use mobil 1 4T, castol edge 4t or shell rotella full synthetic T6.
    Purolator L14612 or Bosch 3300 filter. I dont use the purolator
    Less than $6 each. I don't use the purolator PL series (personal preference)
    Mobil one 4t and rotella are very easy to find and both are good oils.
    But wait..... You need a filter to go with that oil :wink:
  6. mello dude
  7. EvilStig
    EvilStig New Member
    So this Rotella T6 is a popular choice? I've never even heard of it before... though I've heard terrible things about Amsoil, so I try to stay away from that one, personally.
    I did some quick looking and didn't find much viscosity selection online for the T6, and it doesn't say anything about motorcycles or wet clutches... which makes me want to ask, what viscosity are you running, and have you had any problems with slippage?
  8. bitterpil
    Northern Virginia
    5w40 is what you get with the Rotella synthetic. The other stuff is 10w40. Not a big deal it will flow better in low temps but all are 40 weigh in the high temps. Since they are milti viscosity oils. The rotella has a big following with bikers. Not sellj g it but it is a viable choice and is easy to get a hold of.
    As for wet clutch stay away from oils with API rating of energy conserving" or the bewer "resource conserving" lable in the lower part of the API circleon the rear.
    You will be fine with the mobil 1 10w404t. Castol edge 10w40 4t and or Shell Rotella full synthetic blue bottle 5w40. All are Jaso rated and do not have additives that cause clutch slippage.
    You will have to read the back of the rotella bottle to see the Jaso cert.
  9. mello dude
  10. bitterpil
    Northern Virginia
    Its on your first link. Under specifications and approvals.
  11. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    I been quiet happy with the performance of the Shell Rotella 5W40 T6 Synthetic on my 5th Gen.
  12. friedleyjr
    friedleyjr New Member
    Bossier City, La
    I use royal purple 10w40 is what I use at the shop.... never had a complaint or issue from using it. but it is your bike and your choice....
  13. mello dude
    Got it - I'm blind.... :redface:
  14. DaHose
    DaHose New Member
    Napa, CA.
    Can't go wrong with Rotella and a Purolator PL filter.
    Jose
  15. silverbullet132
    Which PL fits the 5th gen?
  16. DaHose
    DaHose New Member
    Napa, CA.
    The 5th gen. takes a PL14612. I see them regularly on Amazon for about $7 to your door. I can't seem to find them locally, though. As I understand it, a PL14610 is taller (so should flow more) and should fit behind the headers/plastic just fine too.
    I stumbled across a thread showing a WRX (high revving turbo engine) running an 8000 mile oil change interval with a PL14610 and Rotella 5w-40 oil. I grabbed a copy of the Blackstone report that shows things looking great and they recommend trying 9000 or even 10,000 miles to see how it does.
    Jose
  17. mikromo
    mikromo New Member
    Independence, MO
    I've used Hondaline HP4 for years, they make a full syn, but I use the blend, and I use it in ALL of my scoots. Good stuff.
  18. bitterpil
    Northern Virginia
    PL14612 or the slightly longer PL14610
    You can also use the standard Purolator filter (still better than most)
    L14612 or L14610 for the slightly larger
  19. Rangerscott
    Rangerscott New Member
    Texas
    The longer PL14610 doesn't fit because of the coolant plumbing in front of the filter.
  20. bzdang
    bzdang New Member
    GTA East
