rectifier regulator
Discussion in 'Mechanics Garage' started by Stretch, Mar 17, 2011.
  1. Stretch
    Stretch New Member
    Marion, Va
    my rectifier regulator went up in flames today...the ones i looked at look different will one from another bike work..if so which??
    Access your search function, a very common topic, but few can claim to have seen actual flames !!
    Where was your camera ?
  3. crustyrider
    crustyrider New Member
    North Country, New York
  4. Stretch
    Stretch New Member
    Marion, Va
    first thing i did....only one close was one from gsxr750 worked on vf1000....brother hooked car charger 12v 40amp up instead of 6v...so yea up in flames
  5. crustyrider
    that shouldn't of flamed it....the bike is a 12 volt system as well...... something wasn't right
    I have one from a CBR on my 86700VFR works great... if your gonna charge the battery tale it off the bike unless your using a trickle charger......
  6. braceyoself777
    braceyoself777 New Member
    Los Angeles California
    Wow, now I'm gonna be afraid that my crotch will catch on fire lol
  7. tinkerinWstuff
  8. Stretch
    Stretch New Member
    Marion, Va
  9. Dainius_M
    Dainius_M New Member
    Lithuania
    Lithuania
    Can anybody to check these wires are it geting hot when engine started (cold engine) and lights off???
  10. Stretch
    Stretch New Member
    Marion, Va
    come on!! NOBODY????
  11. fjf
    fjf New Member
    Mine was really hot due to a weak connection between cable and connectors; I replaced 5-ways connector by direct soldering the cables and, it wasn't hot any more. And battery charging issues ended!!
  12. Dainius_M
    Lithuania
    Lithuania
    Mine hot not 5 ways connector but 3 ways connector and hot are wires from alternator. Connection good.
  13. fjf
    fjf New Member
    3+2 or 5 it does not really matter; if connector is hot, the connection is weak (high electrical resistence) and the assembly warms up (either due to a poor electrical contact cable-to-connector or connector-to-connector). That was my case...
  14. Dainius_M
    Lithuania
    Lithuania
    My connection is good I checked electrical resistence with multimeter (there is no electrical resistence).
  15. Sparks
    Sparks New Member
    Hi Dainius
    You might find that there is little or no resistance across the connectors when using a multimeter as the meter uses very little current . If the plug and socket get hot there is a bad connection ,and the hotter it gets the worse the resistance and so on... It is best to remove the plug and socket and solder the cables together. A bit of a pain if you have to remove the connection on a strip down. Better that then braking down though as I once did on a German autobarn when my main fuse holder melted.Got home to England by using a paper clip wedged in the blackend slot.
  16. Dainius_M
    Lithuania
    Lithuania
    Plug and socket not hot.Hot are wires from alternator. Can someone to check it ??? I think that it's supose to be that. Because I checked wires from alternator on cbr929RR and wires are hot too.
  17. Stretch
    Stretch New Member
    Marion, Va
    the big hole is were the flames came from..haha
  18. Stretch
    Stretch New Member
    Marion, Va
  19. Stretch
    Stretch New Member
    Marion, Va
    i got a replacement and it has 5 wires..mine is four..could this work..seems the black wire is for a 2nd set of brushes..or am i buying yet another one
  20. McViffer
    McViffer New Member
    Northern California
    I need to remember to throw a paperclip in my tool kit...
