Replacement Clutch and Brake levers with smaller reservoirs
Discussion in 'General VFR Discussions' started by Jack1998, Sep 13, 2023.
  1. Jack1998
    Jack1998 New Member
    Hi all
    I recently bought a 2002 VFR800 and have changed the handlebars using an ABM yoke conversion kit. However, I am now having trouble with the reservoirs fouling on the fairing. Has anyone changed their levers at any point and did they have smaller reservoirs with them and if so, do you know where I can find some for delivery to the UK.
    Thank you
  2. notoriousERIC
    notoriousERIC New Member
    Boca Raton, Florida
    ASV Inventions is OEM copy on levers that will work without changing the Master Cylinders
  3. Terry Smith
    I don't know the answer to your question Jack but if you find a suitable replacement master, make sure that the diameter of the piston is the same as the stock set up to maintain the correct hydraulic ratios.
