Reverse shifting for 05' VFR
Discussion in '6th Generation 2002-2013' started by silver_vfr05, Aug 23, 2008.
  1. silver_vfr05
    silver_vfr05 New Member
    Tennessee
    GP Shifting for 05' Pictures and Captions
    Here's how I reversed the shift pattern for my bike. Hope it helps whomever wanted to do the same. Shifter assembly from a CBR929 and misc hardware from the local hardware store.
    The original setup. The shifter is directly attached to the shift rod.
    The foot peg mounting tabs and the main step holder is one piece.
    Used a Dremel with a cutting wheel to cut off the mounting tabs.
    Used the same cutting wheel to bevel a seat for the new peg/shifter mounting bracket.
    Cut out the backside to make room for washers for added support.
    Replaced the original bolt from the 01’ CBR929 part and bought a longer bolt to hold in the peg/shifter mounting bracket because of the added length.
    I reused my VFR peg instead of the CBR929 peg with the peg/shifter mounting bracket.
    Filled the backside gap with washers and a lock washer (not shown).
    Using the large washer to hold everything in place.
    Shortened the spring holder peg to move the spring closer to the inside because the spring rubs against the shifting bar.
    Used safety wire to move the bottom half of the spring towards the inside of the bike and then drilled a small hole and riveted a spacer to the side stand so it would hang lower giving the shifter room to move.
    Without the spacer the side stand and shifter would constantly rub together possibly causing it to jam.
    …And finally the finished product!
  2. whenindoubt01
    whenindoubt01 New Member
    I'm just wondering what the benefit is to doing this?
  3. silver_vfr05
    Tennessee
    What are some of the benefits for doing a mod like this?
    The biggest advantage for ME is that the 3 other bikes I own are GP style shifting and now they all match. The upshift now becomes the more positive shift since it's normally easier to press instead of pull. Another thing I like is that I can keep my foot at a ready position and upshift in a hard left turn without draging my foot. And definitely it's rider's choice. It's a lot of work to do the change and once you do it the way I did, there's no going back unless you buy a new bracket. If that wasn't enough, there's some articles I read on the internet and in some magazines about it.
  4. powderrecon
    powderrecon New Member
    Seattle
    Awesome documentation. Thanks for sharing.
  5. Scubalong
    cool set up, Thanks for sharing
  6. QuietGuy
    QuietGuy New Member
    Cool write-up. Looks like a job well done.
    Not for me though... I doubt I could reprogram my left foot to working in reverse!
  7. supertex
    supertex New Member
    I was just thinking about this topic Sunday while watching the races! Thanks for the thread!
