revised valve clearance
Discussion in '1st & 2nd Generation 1983-1989' started by woodwizzard, Aug 31, 2007.
  1. woodwizzard
    woodwizzard New Member
    somerset uk
    Hi all, just bought vf1000 1984 to do up. I heard that honda released up-dated valve clearances to help combat the cam problem, is this worth doing and if so does anyone know what the settings are, many thanks, Jim.
  2. masonv45
    masonv45 New Member
    I would do a valve adjust on any new bike I just bought. IIRC, the updated valve clearance is .001 higher than stock.
    Plus, doing a valve adjust allows you to look at the cams and verify their condition.
  3. Longerfellow
    Longerfellow New Member
    Pollock Pines, CA
    I seem to remember a "special tool" that actually pulls the cam up toward the cam cap/bearing, then like Mason says the clearance spec is slightly larger. If there's a helpful dealership in your area they should be able supply you with accurate info. It was a service bulletin that applied to a lot of v-four engines of that era.
  4. woodwizzard
    somerset uk
    Thanks for that, I am waiting for a service manual to come through so will check that out and increase the gap as you say. I did take the tops off to have a look at the cams, the engine has 29000 miles on it and the cams look spot on, so am happy with that.
