ride height adjuster
Discussion in 'Gear & Accessories' started by Bikermike, Sep 12, 2006.
  1. Bikermike
    Bikermike New Member
    Does anyone make a ride height adjuster for a 1996 VFR 750?
    After loading bike with saddle bags and camping gear the rear squats down enough to cause pains in the knees on long rides.
    Any suggestions??
    Bikermike
  2. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    Crank up your preload adjuster. Should be a spanner in your tool kit to do it. All '94 to '97 models should include the tool OEM. If you can't get enough preload, you're overloaded or needing a replacement.
    There might be some suggestions for shimming here too, but I'd make sure everything is in good working order before going there.
