Right caliper leaking after pad install...
Discussion in '6th Generation 2002-2013' started by Janny, Jul 9, 2013.
  1. Janny
    Janny New Member
    Winona MN
    so i have a white 2006, i just did my front pads and now 2 weeks later the right caliper is leaking fluid. im wondering if i blew the seals on one of the pistons while i was installing them. is there a place that sells a rebuild kit? i havent been able to find one for a 2006 model.
    thanks
    -->this idiot.
  2. Scubalong
    Where is it leak? Any picture? Did you bleed the system, have you check to see if the bleeder bold is properly torque? I doubt it is the piston seal it it is your break will not hold the pressure.
  3. Kerby
    Kerby New Member
    CT
    you leave the caliper hanging when getting the new pads in or did you secure the piston in a way not to put tension or stress on the brake line?
  4. squirrelman
    Sure it's not a fork seal leak ??
  5. Janny
    Janny New Member
    Winona MN
    squirrelman you are 100% right. i looked at it more closely today and the right front fork is leaking from the seals onto the caliper and rotor.
    F.M.L.
    Now i wish it was just a caliper....
    so! how tough is it to replace fork seals? i assume ill be doing both sides...
