Risers vs. Helibars
Discussion in 'General VFR Discussions' started by mountburns, Jun 8, 2015.
  1. mountburns
    mountburns New Member
    I recently purchased an 07 VFR and after a couple 350+ mile rides, feel the bars need to be a bit higher. I've read about both the Genmar risers and Helibars but still don't know which would be the best solution for me.
    I'm wondering if there are riders in the Portland, Oregon area who have these products installed on their bikes so that I might be able to sit on the bike and feel first-hand what might work best?
    Many thanks!
    mountburns
  2. OOTV
    OOTV Member
    One thing Heli-bars do too is add a rearward offset, so you'll be sitting more up right when riding. I believe it's a 1.25" rise and a 1.5" rearward offset. Genmar risers just add hieght.
  3. Gator
    Gator Member
    Also look at Contivertibars.
  4. Tews19
    Tews19 New Member
    If one uses Helibars do they need to get new cables, brake lines, things of this nature?
  5. Gator
    Gator Member
    Not sure on Heli's, depends on how far they adjust. I know with the Contivertibars I rerouted some lines and moved them up and back a lot but if I go any further I have to replace the throttle cable, not sure on the clutch. But I like it where its at. I think Contivertibars give you more available adjustment than Heli does.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I've got Helibars on my '99 and had to replace no lines, just move them around a little bit. And trim off the line stops.
  7. Tews19
    Tews19 New Member
    Thanks! I will ride the bike and see if I need them. I'm use to sitting upright while riding. Coming from early 70s' 750's and 70's 550s.
  8. sunofwolf
    sunofwolf New Member
    helibars are said to not need new lines-I have a black set being shipped right now, they made two versions for the vfr 800, so make sure you get the latest
  9. stewartj239
    stewartj239 Member
    Syracuse, NY
  10. Veefer Madness
    Veefer Madness New Member
    I had Helibars on my Blackbird and they were fine for that bike but I like my Genmar risers better for my VFR. My wrists don't bother me anymore, they are simple to install, no mods required, and they're quite a bit cheaper than Helibars. Plus I still feel like I am riding a sport bike rather than a scooter.
  11. mountburns
    Thanks for the feedback. I went ahead and ordered the Genmars which should be here Friday so I'm anxious to install them and check them out.
    Many thanks!
  12. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
    I started out with a stock setup
    Fitted Genmar's did a few thousand miles, better than stock but I felt it was still not quite right for me
    Fitted Helibars, absolute transformation. No need to get new lines or cables. LOVE 'EM !!!!
    Ride safe
  13. mountburns
    Thanks!
  14. GigemVFR
    GigemVFR New Member
    TEXAS
    I will put my vote down on the Genmar. Got me a set but have not installed yet. I did a lot of research and reading others comments on how they liked them and these were winner. Most said you do not need to raise very much to change riding position. The helibars also seemed like they were too high as well as I disliked the appearance they gave the bike. I walked into local Honda dealer one day for parts and they had used bike with the Genmar installed. Machined aluminum looked slick and just like they came on the bike. I was sold that day and went and ordered.
  15. Tews19
    Tews19 New Member
    Dead eye, do you have any pics of your set up you can post on here? I installed my helibars last night and want to make sure I did it right.
  16. mountburns
    I ended up going with the Genmar risers for several reasons. First off, I know the a little change can make a big difference when to comes to riding position.
    Secondly, I really wasn't thrilled at the idea of spending another $300.
    I also was concerned the Helibars might be too big an adjustment.
    I installed the Genmars in under 5 minutes and while I've not had time for a long ride yet, have done several rides fro 30 minutes to an hour and feel they're going to be all I need..
    Any previous discomfort seems to have been minimized if not emanating completely.
    I plan on a longer ride this Sunday so will know more after that.
  17. robles
    robles New Member
    I have bought Helibars with my '99 in addition to needed to change not any outlines, just transfer all of them all around a bit. As well as toned from the range puts a stop to.[​IMG]
