Rpm goes up when bars turn all the way to the right. Help!
Discussion in 'Mechanics Garage' started by Speedfreak14, Dec 16, 2015.
  1. Speedfreak14
    Speedfreak14 New Member
    Salem Oregon
    Hello so i jus got done replacing fork tubes and the lower stem (accident accrued) and i put everything back. Went to go check if everything was riding right. Backed outta my driveway then cut the bars all the way right amd it is making the rpms go up to about 3000. I know they say that sometimes the throttle cables will be pulling because i didnt route them right. But i dont really see any tightness in the cables. However i dont know if i did route them the right way. but upon looking at the manual it looks like it is ok. Can anyone help please??
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Slowly turn your bars to the right and monitor the throttle grip, and then repeat and monitor where the cables attach to the throttle bodies. If either are moving, then that's your problem (I'll guarantee one of them is - it's the only way for your throttle bodies to open and the RPMs to increase).
    It definitely sounds like the routing or the cables too tightly secured. Make sure that the cables are free to move a little. If you have zip tied them and they are too tight (unable to move) then that can cause issues in addition to routing.
  3. RVFR
    What Jeff said, you have the throttle cable tied up too tight
  4. Terry Smith
    Just to expand on this, you should always have a little slack at the throttle throughout the full range of motion of the bars. You may need to loosen the cable adjuster, or the routing may not be correct.
  5. Speedfreak14
    Salem Oregon
    Thanks everyone for your replies. Very helpful. Turns out it was my choke cable =/ was supposed to be behind my left fork tube. It was over it so it was being pulled when i turned right. I however have another issue with the breaks. =/ i posted another thread about it. I hope u guys can help me with that as well. Thanks guys!
  6. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Glad you got that one figured out! :)
  7. Badbilly
    On a Harley this is SOP. What it does is automatically accelerate the bike coming oot of a turn.
