rpm
Discussion in '6th Generation 2002-2013' started by deparis, Jul 5, 2003.
  1. deparis
    deparis New Member
    usa
    A couple of questions from a potential BMW GS convert: 1) At what rpm is the engine turning at 85-90 mph freeway cruising speed? Or along the same line, in 6th gear at what SPEED does the 7000rpm vtec kick in?
    2) Can a person make a slow U turn within the bounds of the average 2 lane road or neighborhood street with feet on the pegs safely? (fairly easy on the GS, impossible for me on a Ducati Supersport)
    Thansk in advance.
  2. Hedgehog
    Hedgehog New Member
    Los Angeles
    I'm seeing about 6000 RPM at 80 on my '98 VFR, so go from there. However, I do believe the speedo is about 10% off. The only issue I have on mine at low speeds is the clutch engagement point. But you will get used to it. Unlike the Duck, the VFR has almost unlimited steering head movement.
  3. fireman3758
    fireman3758 New Member
    Nashville, Tennessee
    I have a 2003 and am turning 5200 rpm at 80 mph. The turning is no problem once you get used to the bike.
  4. vfr-xander
    vfr-xander Guest
    6th gear at 6000 rpm = 90 mph. blasting through 100mph comes quickly right after that.
    turning radius is pretty good.
  5. Lone_Texas_Ranger
    Lone_Texas_Ranger New Member
    On my 02 the Vtec Kicks in at 106-107mph in 6th gear. Awesome machine, enjoy it. I do.
