runing without a air box mid and top can it be done fg fh
Discussion in 'Mechanics Garage' started by thefallfan1, May 7, 2021.
  1. thefallfan1
    thefallfan1 New Member
    midlands
    nc 30 hrc 1.jpg scoot.jpg hi guys:uk: im building a vfr scooter fh 750 engine to reduce height ive got to remove air box i know vfr 400 can do it with a hrc kit has any body had a go i know would have to have stage 5 jets etc its got 4 pipes 4 into 4 any help have not finished frame at top i know i have a mini cooper supercharger:Flame: how cool would that be so need to think about pulleys etc if i go that way would be ace:Bolt: picture is nc30 hrc race set up std cv carbs re jeted no airbox
    when dija get out of the asylum ? :eek: no MOT for that rolling abortion !
  3. TOE CUTTER
    You need an air box..............beyond that I am withoot werds...
    thefallfan1 likes this.
  4. thefallfan1
    midlands
    it is still mock up mate , it will have lambretta :scooter: s2 body work ,stainless tank between your your feet etc every thing will be hidden , running 14 inch wheels the pic makes it longer than it is so everything will be weight etc will low .compact. :Bolt: , ive got mint fh 80000 m, got harleys a chop a fatboy . lambrettas etc look squirrel ??? ive not won as many custom trophies as you ~~~ i know its not std BLAND :Behindsofa: just think before you make a comment :monkeydance: ..... you need to think outside the box :locked: sometimes GET GIXXER:thumbs:
  5. thefallfan1
    midlands
    :Bluesbros:
    BORING gray squirrel :Behindsofa: get a gixxer :Bluesbros: and listen to MOGWAI
  6. thefallfan1
    midlands
    I GET IT that cv carbs need to be in nice jap factory designed set up for air pressure etc but ive tried on my std fh with out top on you just get bottom end 3000 rpm thats with dyna jet stage 2 . wont rev so if i put velocity stacks like new carb models, and stg 5 jets ??? othewise will have go down , supercharger route with dellorto carbs NOBODY done drag racing set up OR kit car set up away from factory ????/
