Running Out of Gas---Sort Of
Discussion in '1st & 2nd Generation 1983-1989' started by cromanyak, Apr 20, 2008.
  1. cromanyak
    cromanyak New Member
    I went for a ride yesterday and just as I pulled in the driveway the bike stalled. I looked at the fuel filter and no gas. So I put some in today and it would only take two gallons so it definitely wasn't out. Anyone know what could cause this? When does the reserve come on?
    Chris
  2. koorbloh
    koorbloh New Member
    Lynnhood, WA
    well....did your fuel pump die?
    did your fuel filter clog?
    did your bike start up with more gas put in?
    is your petcock messed up?
    reserve "comes on" when you turn it on ;), did that help?
    all these things we must know.....
  3. cromanyak
    It's gravity fed.
    The filter is fairly new.
    Yes.
    I don't think so. Could the screen in the petcock bowl cause this?
    It was on reserve. I just keep it there all the time.
    Any ideas?
    Chris
  4. koorbloh
    koorbloh New Member
    Lynnhood, WA
    so...what bike are we looking at then? My 87 vfr700 has a fuel pump....
    if adding more gas made it start...then...I'm stumped.....
    I'd look at your petcock....
  5. cromanyak
    It's an 86 VF500F. I'm thinking it has to either be the petcock or it's not getting gas while going uphill for some reason. It ran out after I climbed a long hill.
    Chris
  6. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Why would you keep it on reserve all the time? Could be any of the above suggestions.
