Rust out of a Gas Tank
Discussion in '1st & 2nd Generation 1983-1989' started by Dean_Fuller, Oct 2, 2006.
  1. Dean_Fuller
    Dean_Fuller New Member
    Knoxville, Tn.
    I have removed rust from the gas tank using various chemicals and a pc of chain....seems to of done a fine job just by looking with a flashlight after the fact....my question is this. When I go to remount the tank and put gas back in...should I rinse the tank with something? Just to make sure any chemicals are gone? I have used rust remover, stripper and phosphoric (sp?) acid...thanks....and I hope I'm not posting more than I should. I seem to be the only one asking questions about these old bikes right now.
  2. MrJoelieC
    MrJoelieC New Member
    Milford NH
    I need to do this as well...But I have been told you can get a can P.O.R. 15 follow the instructions on it and viola you have a cool tank....
  3. Dean_Fuller
    Knoxville, Tn.
    P.O.R. 15????? Never heard of it. Can you elaborate? Is that the real name? Where is it available?
    Thanks, Dean
  4. SA1713
    SA1713 New Member
    There is another method called Red Kote. It is a good bladder for these sort of things.
    http://www.damonq.com/TechSheets/Red-Kote.pdf#search='red%20kote'
  5. Markp
    Markp New Member
    You should rise it thoroughly. I would probably use water first, followed some mineral spirits, once rinsed thoroughly drying it makes sense. Any remaining residue should not hurt anything but I'm not a chemical engineer. I'm just telling you what has worked in the past for me. Once gasoline is back in it, rusting should be minimal.
    If anyone has better idea's I would love to hear them, I have to do my VF1000F tank soon. I was planning on using hydrochloric (muratic) acid, but I'm not married to that idea. I do know the stuff strips steel fast and when rinsed well and covered with WD-40 does not oxidize easily.
    POR's instructions indicate to flush with water and dry with compressed air. They use Potasium Hydroxide and Phosphoric Acid in their products. The base (Potasium Hydroxide) strips and the phosphoric acid etchs the metal so that the POR 15 will adhere better.
    Mark
  6. MrJoelieC
    Milford NH
    Man..... You guys ever hear of google? :tongue:
    http://www.por15.com/
    They have a gas treatment solution.... you can get at almost all of the major automotive super centers or I have heard that the Honda Motorcycle Parts department actually sells it as well.... Rumor though....:confused:
    That's all I got....:noidea:
  7. Dean_Fuller
    Knoxville, Tn.
    Thanks...I will look in to that ASAP...
  8. Kusskid76
    Kusskid76 New Member
    Buffalo NY
    Hi, I'm a newbie here but my father used to run a cycle shop and his recipe for rust out of a tank was muriatic acid(pool acid) and aquairium gravel the rinse with gas. NEVER USE WATER IN A GAS TANK. Trust me I learned this the hard way. Good luck
  9. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    i POR -15 on my 86 tank and it works great you should try it
  10. okiengr
    okiengr New Member
    Wichita, KS
    I have used KREEM before and it worked well. There's a metal etcher to eat the rust from the tank, then a prepper, and then a liner that you dump into the tank to coat it. Never had rust issues again on that bike.
    http://www.instantop.com/CyclePage/Kreem.htm
  11. Spike
    Spike New Member
    I would say clean (even of chemical residue) and dry is the safest bet. But don't know for sure, only used a Kreeme kit in the past.
  12. restlesswildman
    restlesswildman New Member
    Cincinnati, Ohio
    find a radiator shop and have them clean it out for you. Than have them epoxy the inside of the tank. I had one done for $55.00. Best money spent!!
  13. reg71
    Sikeston, MO
    now that sounds like a much better deal to me. I was thinking I might have to do it to my old VF500, but if I can get someone else to do it, that's even better!:smile:
