Scraping pegs while hanging off?
Discussion in 'New Riders' started by jaimev34, Oct 18, 2009.
  1. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Today I went up and down my favorite mountain twisties. The front side of the mountain is comprised of very tight, decreasing radius turns. The back side is made up of sweepers that allow greater speed. My problem today was on the front side: I was hanging off on a couple of the very tight turns and two times I scraped peg (not the feeler, but the actual peg, since I removed my feelers). I believe I have the correct technique -- 1 cheek off the saddle into the turn, knee out into the turn, butt back, body low, upper body into the turn, and head low near the turn side mirror. I don't know if this description if confusing, but basically I followed the directions in Keith Code books, track school, and race vids. Anyway, I'm wondering what my problem is because hanging off is supposed to reduce the amount one needs to lean,; therefore, peg scraping should not be occuring. I'm going fast, but not too fast; all the little CBRs and GSXRs use the mountain as a race track and go faster than me. Is it because the VFR's pegs are lower than the RR bikes? Am I not hanging off enough?
    Just wondering if any of you peeps can provide some insight.
    Thanks!!
  2. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    are you trying to drag knee or go faster around corners :confused:
  3. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Trying to go faster around corners with less lean angle.
  4. matt1986vf500f
    the only thing i can share with is get further off the bike, i drag feelers alot but i keep myself close to the bike i.e. not hanging off of it
  5. Joey_Dude
    Joey_Dude Member
    North Georgia
    A suggestion, have you looked at your lines as you go through a curve? You want to be as smooth as possible and do as little sharp turns as you can.
    Try watching motorcycle races, you'll notice that they don't make real dramatic turns, rather they start turning well in advance of the actual turn so they can carry a lot of momentum.
    For what it's worth, I've never dragged a peg while hanging off and I've actually gone faster than some of the liter bikes up in the mountains. When you approach a curve are you going fast then braking hard, then making a sharp turn? If so, next time try reducing your line angles. For example, say, you see a left-hand curve. What you can do is get on the right-most side of the lane and as you approach the curve made a gradual turn to the right-most lane.
    Here's a good video by Valentino Rossi: http://www.ebike-ridingtips.co.uk/video/mediaplayer.swf?file=rossi.flv
  6. Fizz
    Fizz New Member
    San Diego, CA
    Even if you have your butt off the seat you still have your upper body to worry about. This guy has the butt part right but the upper body is counter-leaning.
    Your bike's almost 150 pounds heavier than most sport bikes and you're a tall guy, you won't be able to match lean angle even if you match entry speed and line everything else the same.
  7. NorcalBoy
    somewhat low footpeg location, incorrectly set sag and sacked out suspension components can all play a hand in this.
  8. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Along with the actual curvature of the road itself. Remember, public roads are generally crowed, even a little bit, and that can cause clearence issues too.
    BZ
  9. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I guess I think it's weird that I still have some chicken strips on my front tire, but my pegs are scraping. That's why I think the pegs are low. Norcalboy made a good point about the suspension, though. I'm not too heavy at 170 lbs, but my susp. components are old and may need to be tuned up. Plus, my susp. needs to be redone to my weight (springs, valves, oil).
  10. reg71
    upgrading suspension helped this problem for me...
  11. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    What did you do to your susp?
  12. squirrelman
    THAT'S normal. It's geometry.
    On most sportbikes you can use the rear tyre to the edge and still not be using the full width of the front.
    Look around at the next bike meet......
    Back in my sportscar autocross days, we used to check tyre/suspension/air pressure setup by drawing chalk lines across the tyre tread and seeing clearly how much rubber was in contact with road after a run.
    Chalk your tyres and c what u c.
    The VFR is relatively heavy, and you'd need to be Reg Pridmore or Fast Freddy Spenser to keep up with lightweight CBR's. Don't try to exceed your or the bike's limits.
  13. RVFR
    So many variables to this, but for starters the VFR does have some low hanging bits which don't help, but add in suspension miss ques, weird of camber road bows and the like, you'll find yourself touching here and there. Joey made mention of said entry lines too, all this all plays into the equation.
    If you are doing this on a public road,which it sounded like you did, I'm not preaching the warning we've all done it, but in today's light this is best figured out at the track where you can work out this and that and do it being as safe as possible. As you have figured, there's more to it than just body position, speaking of, where's Tori's feedback?
  14. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Hey, RVFR, delete some of your PMs so I can send you one; your inbox is full. I have a question about Loopsies.
  15. RVFR
    LOL Thanks, Done, you're good go..
  16. John451
    John451 Member
    You might like to check out the below short low side Vid showing what can happen after a VFR800s centre stand decks out on a decreasing radius left hander, gotta love how he slides then roles onto his feet before stopping...:cool:
    Lowside on the Oxley
  17. drewl
    drewl Insider
    Virginia Beach, Va
    It's them long ass limbs you got.
    Just kiddin' Reg has the rear shock up-grade. Ohlins is one of the most popular but expensive. Penske used to make one, not sure if they still do. A lot of folks do the fork re-spring and valve up-grade as well. I doubt you would be very comfortable if you tried to raise your pegs, but that would keep them off the road.
  18. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I've seen this video--not good!!
    I'm not taking these turns too quickly, so I'm trying to figure out what I need to change technically and/or mechanically to prevent what happened in the video. I've got these pilot powers on my bike that give me all kinds of stick and these damn pegs are ruining it. But it's probably a good indicator that I can't push it any further.
    About the turns, Joey, may have a point. Next weekend I'll test this. Normaly I try to delay the apex so that I have more visibility in the turn. This is especially the case for long turns and decreasing radius turns. If I initiate the turn too early, I'll run out of pavement because some of these turns keep going and going.
  19. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    My mechanic is pretty efusive about a shock made by Wilber or something like that. He recommends it over penske and ohlins.
    I'm thinking my bike will benefit more from a front end makeover initially and then I'll do the rear. Springs for my weight and gold valving, plus oil should make it handle better, but I'm not sure if that will solve this peg scraping thing. I must study this further. Reg says his susp upgrade helped so theirs hope.
  20. John451
    John451 Member
    The then owner of belows Gen 6 also preferred his Wilbers over Ohlins, from memory one reason was they were more approachable to his enquiries and the people he spoke to and suspension wise were very tech savey.
