Seized Brake Pistons - Solutions ?
Discussion in '1st & 2nd Generation 1983-1989' started by straycat, Nov 17, 2022.
  1. straycat
    Hi Fellas, a question for you guys re freeing up seized brake Calliper pistons.
    My Project CB900F, was left in a barn with no brake fluid in it, front callipers removed and rear one still on.
    both front a rear Master Cylinder are seized solid and will need replacing, the calliper pistons similarly seem to be seized.
    I suspect in all cases once the fluid is drained, what ever fluid is left in there, being hydroscopic, attracts moisture and then you get galvinic corrosion between the pistons and the calliper.
    Ive got them soaking in WD40, but im not hopeful in getting the pistons out even after that.
    Any other ideas on proven remedies out there ? or am I looking at new replacement callipers ?
  2. RogueRC24
    If it was me (and nobody wants to be), I would probably try and used compressed air to get pistons out or some large jawed pliers and pull the pistons out. Then I would take the whole caliper to the sandblaster to try and remove corrosion. Then an air blowout followed by ultrasonic cleaning, alcohol cleaning, sanding if necessary (to smooth out any rough spots), and final cleaning to salvage the original parts. This is just me though and with the understanding that rebuild kits are available. - that was for the seized calipers.
    Master cylinders...haven't pulled one apart yet. sorry Stray. Possibly (with rebuild kit available), just ultra sound those suckers and see if you get movement back.
    I use dish soap for cleaning, nothing harsh to destroy o-rings and such.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    The master cylinders should knock out after a few days soaking
    Calipers, I’d look for some others rather than struggle with little saving
    I have a 1100 Shadow master cylinder (that I keep "bled") mounted on a piece of pipe just for this reason. I mount it in the vice and hook up my problem caliper. Pump them right out. Use a shim to keep one piston from popping out and before the other. You can get them right to the end and usually wiggle them with your fingers to release at that point. If not, compressed air will now be able to do it, when it wouldn't budge them "as delivered".
    Then I cap the hose with a bolt, crush washers and cap nut for the next shitty time. I've used it SO MANY TIMES. And it keeps the mess and caustic brake fluid away from the rest of the bike.
    jstehman likes this.
    With my aux master, I've popped a few calipers open I was sure were fucking toast. The pistons look new. Ultimately, it can depend on where the pistons were when they were sent to the bottom of the ocean for 10 years. Pushed mostly in, ups the success rate of finding decent pistons. The caliper bores themselves I can almost always clean up.
    I figure it's worth a few minutes of hooking them up to see what I really need to move forward. Maybe I only need two new pistons, instead of four.
  6. jstehman
    jstehman New Member
    A grease gun has worked for me before.
    Sent from my SM-N950U using Tapatalk
    Agreed. But I'd rather spray the calipers out with a little Brake Kleen when I'm done.
  8. straycat
    Cheers Guys, ill give that a try.
    I managed to get the 4 front pistons to move, hit them with WD40 inside and out, some heat and more WD40.
    I pushed them in just a wee bit with a big ass C-Clamp, ten used my piston pliers/grips to twist and rotate them. Theyre back soaking again now so that my just pop out with air or hookup to a MC as you suggest !!
    thanks again for the tips.
  9. raYzerman
    raYzerman Member
    Millgrove, ON
    I like the m/c idea rather than air... more control..... just leave the old pads in as a spacer to keep a piston from popping out before the others are out enough to work on. You got them moving, that's good news.
  10. straycat
    Fronts are out.
    Rear M/C may be functional so ill see if I can fill/bleed and use it to pop the rear pistons
    RogueRC24 and Captain 80s like this.
  11. Colddevil
    Colddevil Member
    Wisconsin
    Related--I started pulling taking apart the front calipers on a VFR700, and... wtf?
    I took off the dust cap pieces on the pistons, and... there are wood plugs in there. I almost have the pistons out. Maybe I use a nice little wood screw in there to see if I can give me something to pull on for removal, lol. Maybe I'm naïve and this serves a purpose but I can't figure out what it would be.
  12. raYzerman
    raYzerman Member
    Millgrove, ON
    Is that what they mean when they say the brakes feel wooden? :eek:
  13. Phil Robertson
    Phil Robertson New Member
    > Maybe this serves a purpose
    possibly squeal?? chatter??
    Yeah, they are for noise. They are only a few mm thick. Pretty sure in the past on a couple I have removed them and spun the piston like every other caliper
  15. Colddevil
    Colddevil Member
    Wisconsin
    Cap, when you say "spun the piston", do you mean that you turned them the opposite direction so that the full piston isn't full of fluid? It would seem to make more sense "backwards" of how they were installed and just leave the cap and wood piece out.
    Yep. Just make sure the area that has been exposed isn't corroded or damaged that it will foul the seals when installing.
    Ran either way is just fine tho. I think a bike I bought was missing parts and I just went that route.
    Colddevil likes this.
  17. Colddevil
    Colddevil Member
    Wisconsin
    Interesting, thank you! I've got some good condition VF500 ones that are 2.5mm taller but have no corrosion on the important side. Dry fitting with the old pads looks like they'll still have space to get around the rotor. I think I'm going to go with that and save me some money. Neat.
  18. RogueRC24
    Never seen wood anywhere near brake components! Freakin cool.
  19. squirrelman
    the nt650 uses the same wooden pucks but they usually get lost during pad replacement. no doubt, the wood tends to prevent some heat-transfer from the hot pads into the brake fluid.
    RogueRC24 likes this.
