Shifting problems
Discussion in 'Mechanics Garage' started by wgramenz, Aug 14, 2009.
  1. wgramenz
    wgramenz New Member
    Sometimes when shifting from 1st to 2nd on my 08 vfr, I get stuck in neutral where you hear a clank clank clank, and then sometimes it finally shifts. I have cleaned and relubed my chain over and over, and I can't think of any reason the bike would do this. My bike has just over 4,00 miles on it.
  2. Knife
    Knife Member
    Downingtown, PA 19335
    I don't know about an '08, but on my '98 I have to pre-load the shift pedal to get a smooth shift from 1st to 2nd. This works every time. If I don't, I often miss the shift and it's difficult to then get it into 2nd. Try that. Maybe it will help.
  3. GoForARide
    GoForARide Banned
    The problem I have is that in between 5 and 6 it kinda goes out of gear.
    Someone here once showed me a product that was kind of a spring that helped you shift a bit better.
    iv been meaning to ask for a link for that product again.
    so...
    anyone know what im talking about?
  4. betarace
    betarace New Member
    Middleburg, VA
  5. betarace
    betarace New Member
    Middleburg, VA
  6. Knife
    Knife Member
    I bought that kit several months ago. Doesn't work well in the box sitting on the shelf. Guess it's time to install it. Thanks for the nudge!
  7. NorcalBoy
    I have this problem shifting, it bothers me. I bought the parts to fix it, but I left them in the box and came up with some goofy workaround way to shift instead. :thumbsup:
  8. Knife
    Knife Member
    Well, I guess some of us just aren't as smart and experienced as you say you are. :thumbsup:
  9. NorcalBoy
    It really isn't all that ironic.
  10. deepdish
    deepdish Banned
    you are not shifting hard enough really pull up on it and do it fast and with precision..........:thumbsup:
  11. deepdish
    deepdish Banned
    :whistle:..............
  12. deepdish
    deepdish Banned
    :pop2:.........................
  13. v4pwr
    v4pwr New Member
    cleveland, ohio
    i'm not hands on familiar with this generation but maybe try flushing the clutch fluid. mine seems to get a buildup of gunk right at the inlet hole of the clutch master. i clean it and good to go. i think moisture is getting in somewhere causing the problem i had. maybe yours will be just as easy.
    if you pop the cap off and find the fluid brownish get a clean suction device and suck it ot then flush clean fluid through. don't try and flush the old fluid through to clean it out. hope it helps
