Shock Oil Recommendations?
Discussion in '1st & 2nd Generation 1983-1989' started by cooldadonavf500f, May 27, 2024.
  1. cooldadonavf500f
    cooldadonavf500f New Member
    Got all the seals and parts to rebuild my shocks, but I can’t find any info on what weight/grade of shock oil to use in the maintenance manual. does anyone have any guidance?
    thank you!
  2. Terry Smith
    I assume you are referring to the front forks? The service manual refers to using ATF (automatic transmission fluid) with 332mL right and 335mL left.
    cooldadonavf500f likes this.
  3. cooldadonavf500f
    Yeah I saw the volumes, but no mention of the oil weight. If it’s just ATF, I won’t need to order anything.
    edited to add: [smacks forehead] that’s what “ATF” meant in the manual!
    Go by oil height, not volume.
  5. cooldadonavf500f
    That’s right. Thanks for reminding me. I should watch a few more videos before I do this.
  6. bmart
    bmart Insider
    Charlotte, NC
    And a bit like tire sizes...oil weight doesn't' really ring true. 10W isn't always 10W like another brand. And when it is cold/warm...still more variation. And if you look at Ohlins...have fun with their number scheme!
