Side Mounted Radiator Woes - 1998 VFR
Discussion in 'Mechanics Garage' started by spicyramen, Oct 10, 2021.
  1. spicyramen
    spicyramen New Member
    CA Bay Area
    Hello everyone new member here :bruce2:
    After buying my 98 vfr, I went through a complete fluid change to freshen up everything. New oil/filter, brake/clutch fluid, and coolant change. Lately I noticed a weird issue where the left radiator isn't heating up at all. During some rides I can feel both of my legs cooking nicely as the radiators barf out hot air, but some rides one leg is getting the cold shoul... knee. When I pull over to feel the radiators, the left radiator is stone cold! Thankfully the temperature still stays within spec, but I'm worried about hotter months.
    My first guess is air got into the system somehow so I'll post an update when I :gulp: the coolant. Before that though, anyone else have this problem?
  2. Terry Smith
    I only ever followed the service manual instructions and never had an issue. Refill the coolant whilst on the sidestand, start the engine and blip the throttle a few times to burp out any air, and top up as needed. At a minimum you need to check that you have properly filled the system. What is happening in the reservoir tank?
    spicyramen likes this.
  3. mello dude
    Romania
    Just did this service on my own bike.. A tip is to fill up on side stand per manual, but also tap (lightly!) the bottom of the left radiator with a rubber/acrylic hammer. This helps any air to rise to the top to the fill port. Of course then also give the center hose some light squeezes too. Mine worked out good to go on the first try.
  4. spicyramen
    CA Bay Area
    Sorry for the late posts everyone! It sucks not having a garage to do work. I followed the Haynes manual and heated up the bike, got the fan running, carefully opened the reservoir cap, and blipped the throttle to get some air bubbles out of the system. I also gave some love taps (advice from mello dude) to the radiator but I think all the bubbles were already out. I then refilled the coolant reserve to the proper height. Both radiators are getting as hot as they should.
    RllwJoe likes this.
  5. RllwJoe
    RllwJoe Insider
    Good to hear that you sorted it out.
