Sight glass on A6 clutch cover.
Discussion in '6th Generation 2002-2013' started by Mousejockey, Apr 11, 2015.
  1. Mousejockey
    Mousejockey New Member
    Manchester UK
    Hi.all. Does anyone known how to safely remove the sightglass from the clutch cover of a 6th gen vfr 800?
  2. Expvet
    Expvet New Member
    Brooklyn, NY
    Never tried it myself. But out of curiosity, what happened? Never seen a glass that fogged up before.
  3. Mousejockey
    Manchester UK
    It isn't fogged up. I put some tape over it to shot blast is. Now gonna powder coat it hence why I want to remove it. If I can find out how too :)
  4. Allyance
    Allyance Member
    Germany
    East Bay, California
    Is it truly glass or plastic? If it is glass it should withstand the moderate heat of powder coating, however, different co-efficients of expansion may cause it to separate or crack. Hopefully someone else has already done this without a problem.
  5. tinkerinWstuff
    I used an oven baked enamel on mine and didn't run the temp higher than engine operating temps 240f-ish. Another 100 degrees to Powdercoating temp and it would likely still be ok, but has risks for sure.
    The guy doing the clear clutch cover mods (Sebspeed) probably has the answer.
  6. zoom-zoom
    zoom-zoom Member
    BC, Canada
    When I had my clear clutch cover done by Sebspeed over on VFRD, he said he would press the site glass out for me so I could get the cover powder coated. Not sure how he pressed it out mind you. Like Tink said maybe shoot Seb a PM and ask. I think Seb is a member here as well as VFRD, but don't think he spends as much time on this site.
  7. Mousejockey
    Manchester UK
    Good advice guys. :) how long did your clear clutch conversion take zoom-zoom?
  8. zoom-zoom
    zoom-zoom Member
    BC, Canada
    From time I sent the cover to Seb until returned it was about 4 weeks. This was over the Christmas holidays though so shipping times were longer than usual because of the holidays.
  9. Mousejockey
    Manchester UK
    Thanks zoom-zoom I may mood into getting that done :)
