single vs. double
Discussion in 'Mechanics Garage' started by cstmvfrguy, Nov 7, 2008.
  1. cstmvfrguy
    cstmvfrguy New Member
    foot of the dragon
    I have an 86 vfr 700 and i am thinking of doing a single sided swingarm how much work is involved with this mod? Also wondering the pros and cons to going to a sssm any experience would be much appreciated. I'm also wondering if anybody has any other suggestions for performance upgrades on this bike I already have supertrapp exhaust k&n smaller front sprocket (in Proggress) wider tires and brakes off a cbr 600. I love my bike but i am always looking for the next project. :rambo:
  2. supertex
    supertex New Member
    I've been wodering this myself. How much is involved in fitting a third gen piece
  3. willi777
    willi777 New Member
    There was a page i stumbled across- http://www.rc30.us/ -years ago where the owner tried to fit a VFR800 swingarm on his 86 VFR750. Of course there is nothing on the page now, that i see, regarding the swap, so i will send the e-mail reply i got when i inquired...
    "The swingarm came off of a VFR800, and DOES NOT work!! It's back off the
    bike now, and I've put the stock swingarm back on it with an F3 rear wheel.
    I had to have the shock mount moved back to the original location, too. The
    dimensions just didn't work out. The sprocket was too far to the left and
    the wheel centerline was too far to the right. It would have required MAJOR
    surgery to get it to work, and I'm just not that dedicated!! I finally got
    the bike on the road about a month ago though with the F3 wheel, first time
    I rode it since the 840 conversion. It feels a LOT stronger, but I'm still
    in break-in mode so I can't really flog it properly yet."
    When i saw the page, there were pics- the shock mount was cut out of its location in the middle of the frame, and rewelded to the left to match up with the shock- pretty major surgery, and then it didnt work out, that is brutal... but ya gotta try it to find out.
  4. twopearls
    twopearls New Member
    this is a simpler & better performing project ... makes a huge difference in handling, traction & tracking ...
    CBR F2 Conversion - Rear
  5. cstmvfrguy
    foot of the dragon
    thanks i've got the cbr wheels with a 160 series tire i'm having trouble getting anything wider to fit without rubbing the brake arm. any ideas.
  6. Rev
    Rev New Member
    Olympia,WA
    Modify the brake arm.
    I haven't heard of anyone making the mod you are asking about, but here is a link you may find useful: Honda Swingarm Dimensions
  7. supertex
    supertex New Member
    What about using a swing arm from 87 400. Frame looks the same. Would be hard to find though.
  8. SAFE-T
    SAFE-T New Member
    www.ebay.uk has these all the time, the difficult part being to find someone who will ship it to you. I have had several wheels sent to me from Britain using DHLonline - about 30% of the cost DHL normally quotes - this was a few years ago, but still worth a try.
  9. willi777
    willi777 New Member
    Wow, i never thought of using a VFR400 swinger... might just be the ticket to pulling off the ssa swap on the 86 since the frames look really similar.
    Modding the brake torque arm... USE CAUTION here...from what i have read, i think through Cobalt racing and on the old VFR forum, any tire over a 160 is going to cause more stress on the swingarm than it was designed for. The bike came stock with a 130 bias-ply rear tire...not very sticky compared to a modern radial tire.
    But if you must, here it is from the link in post #4 above
    ...First you will make room for the wider wheel. The "I-beam" caliper stay will need to move in order to make enough clearance for the F2 wheel. This can be done the barbaric way—by grinding the "][" down to a "[". Or you can choose, as I did, the aesthetically superior way (yes, art snobs even exist in the motorcycle community). This can be done by moving the stay to the outboard side and bending it in a slight "S" shape. I did this after the wheel was properly positioned so that the spacing would be right. It was bent easily with nothing more than a vice and some elbow grease. Note: Make sure you use a bolt that clears the rear brake master cylinder on the swingarm stroke
  10. TAGLICIOUS
    TAGLICIOUS New Member
    Coeur d'Alene, Idaho
    the afore mentioned description
    elbow grease to bend a swingarm to fit for a sss vs a dss? you must want to die? The aluminum needs to be bent with heat then made sure it's the right alignment (with heat as well) then let it sit and cure... don't dip it. This what you are refering to? If I were you---I would buy a swing arm for the express purpose of if it doesn't fit... you could easily sell it and not have hacked a swing arm to TRY and make one yourself. That being said, good luck and for jiminy sakes... be careful trying to make stuff work remember the torque put out by an SSS... keep us posted... I know a few guys that may be interested in this hillbilly type of mod :cheersaf:
  11. squirrelman
    i've got the swingarm, shock, and linkage from a '96 that i need to sell.......$335, will separate.
  12. supertex
    supertex New Member
    Check again guy I believe they are talking about the caliper stay not the actual Swingarm. That would be nuts.:crazy:
  13. emptyskull
    emptyskull New Member
    near the bat cave
    I would go with the triple sided swing arm and have 2 back tires..
  14. leftcoast
    leftcoast New Member
    somewhere near Seattle, but my heart is just north
    how 'bout just buying a 4th or 5th gen? :unsure:
    JAT..................................
  15. willi777
    willi777 New Member
    Its all about the weight for me... the '86 is as heavy as i like, but i'm only 145 soaking wet. Speaking of weight, adding a single sided swinger is going to add a decent amount of weight, compared to the stock swingarm, which is pretty light. i think the trade off- a much beefier swingarm and wider wheel, not to mention the bling factor, are worth it, but that's just my two cents. The best bang for the buck would probably be aftermarket wheels... the F2/F3 and VFR rims are really heavy when compared to a marchesini or Dymag rim.
  16. supertex
    supertex New Member
    Can I buy one for $300? That's why. Besides, less fun that way. :cheersaf:
  17. TOE CUTTER
    Are you still interested in this mod?
  18. cstmvfrguy
    foot of the dragon
    i've kinda forgotten about it but any info would be nice in case i decide to tackle this project next year. have you done it or know someone that has.
  19. TOE CUTTER
    I have seen it done before so I know it is possible. I just picked up a wheel and swing arm to install on a 86. I will post pictures if you like.
  20. supertex
    supertex New Member
    What year are you trying to make work?
