Slave Cyl Replace or Rebuild? (Pics)
Discussion in '1st & 2nd Generation 1983-1989' started by xenocide, Mar 28, 2007.
  1. xenocide
    xenocide New Member
    Is the wear here bad enough that I should look for a replacement or can I clean it up with some fine steel wool?
    More pics here.
  2. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    some fine steel wool and some new seals and it will be fine. I redid mine it was 20 yrs old and works great be sure you replace the gasket, too. Apporx imate cost for parts from bikebandit.com $14 plus shipping. 1 gasket 1 oil seal and 1 piston cup
  3. reg71
    Sikeston, MO
    yeah, I agree with Danimal. That doesn't look too bad. You'll be able to get 'er fixed up in a flash.
