Smartphone Mount
Discussion in 'Gear & Accessories' started by nookiaz, Jun 12, 2019.
  1. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    Hi Folks,
    I'm looking to get a a mount for my Iphone 7+ on my 5th Gen . I've seen the RAM fork stem mount with the universal X-grip. Any one with other mounts to suggest? Thanks for the inputs.
  2. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    RamMounts also make a handlebar U-bolt mounting that works great for mounting where the tank
    bolts are. You throw away the U-bolt and use the flat bar to bolt to the tank mount area. Use some
    longer bolts and away you go.
    Arclight likes this.
  4. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Is it this one?
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Not sure if that's the correct one, but that's the general concept. I can look through my order from way
    back when and see what the correct number is if you need it.
  6. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    Many thanks,
    Will check RAM gear out.
  7. squirrelman
    what's happening around and in front of you while you're foolishly looking down at your phone ?
  8. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Your right. I can’t say that there is any real reason to have the phone directly in front of my face.
  9. Norse
    Norse New Member
    Denmark
    GPS?
    That's what I use it for. And unless you are basically blind or your helmet has a drinking straw where the visor should be, you barely have to glance down for a ½ second to get your bearings. It is no different than glancing at your mirrors.
    Anyway. I use a RAM mount with a fork stem adapter (adaptor is SW-Motech). Best option I have tried.
    Zarb likes this.
  10. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The same thing that is happening when you foolishly look down at the speedometer, mirrors, tach, or glance over your shoulder.
    Simply no biggie, and beats the heck out of trying to use a map on a tankbag, and you can take that to the bank.
    RubiconMike and Norse like this.
  11. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    The main reason for mounting my phone is that it has a wireless charger.
    I mean it’s not convenient to use the phone because of the riding gloves and the touch screen.
    Kind of forces me to be hands free.
  12. Norse
    Norse New Member
    Denmark
    BTW.. Just remembered something that might be a factor.
    I have used the same RAM mount and fork stem adapter on other bikes. On one of them I was hit by a car. Car did a illegal left turn from a parked position and plowed straight into the side of my front. Bike got slammed down, caught on the car and dragged (with my foot pinched under it) for about 25 yards.
    I had my phone in the mount. Bike was totalled but the phone was still in mount. Didn't move a mm.
  13. CDA441
    CDA441 New Member
    Belgium
    RAM mounts are the best. I personally use quadlock mounts because they are more secure than the RAM X-grip, they lock in and you need to press a lever and turn them to get it out of the mount. Quadlock also exists as a universal backing plate for phone cases (or without case).
  14. Yawk-oh
    Yawk-oh New Member
    Finland
    I was looking for a good solution to mount my phone on the bike. While I've had good experiences with RAM ball mounts, I've never been completely happy with the X-grip I've had for a couple of years, so I looked for other options and found these on aliexpress. The bike side mount attaches to the clutch/brake reservoir clamp screws and the phone side mount is a universal adjustable one. I use a RAM mount arm.
