smooth shifting
Discussion in 'General VFR Discussions' started by crgvfr800, Jun 13, 2008.
  1. crgvfr800
    crgvfr800 New Member
    Cleveland, North Carolina
    hey everybody...i just got my 04 VFR a cpl weeks ago.....and in the past i have always used a cable clutch in stead of hydraulic and to be honest ive been having trouble adapting to it....on both shifting and on starting out...any tips on how i can get it all smoother...or is there anyway i can adjust that clutch to make it a lil more forgiving? any help or suggestions would be greatly appreciated...thanks
  2. v4pwr
    v4pwr New Member
    cleveland, ohio
    only suggestion i could offer is just let the clutch out a little slower with a little more rpm too smooth it out. you should get used to it rather quickly, i noticed a slight difference when i got mine. the clutch seems to operate in a smaller range than a cable operated one. it only took me a couple days to get used to it. im not sure exactly where i rev it to when i take off but i would guess somewhere between 2000 to 2500 then let the clutch out slow and steady and off you go.
  3. crgvfr800
    i think my biggest problem is starting off out of a gravel driveway...it seems that ill either spin the rear tire or stall the bike i get sooo frustrated....i think it may just be all in my head though
  4. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Try changing the position of your clutch lever and see where you get the most control. I recently adjusted mine closer while on the fly and it made a world of difference.
  5. crgvfr800
    what is the best way of going about doing that?
  6. drewl
    drewl Insider
    Virginia Beach, Va
    feather is the key word. smoothe transition like when you first drove the stick shift...
